Saurav Nayak
Recruit
Well the title explains almost everything and I'm new here and to all things forum so please bear with me if I made any mistakes below ... With that said,could you all help me with the config...like which cpu and motherboard and the rest parts (I need a extra free gpu slot for future expansion)
should I take as not to bottleneck my gpu
Also I would like the costs to be as low as possible...budget is around 70-80k
4 ram ports on motherb would be a boon too..
Included the link to the graphics card I want to use...thanks a lot for your help
http://www.amazon.in/GeForce-Dual-F...AL-GTX1060-O6G/dp/B01IPVSN1S/?tag=tzlaptop-21
And yes sorry for less info but I'm hoping to base the build around the gpu and not the other way around
