Budget 0-20k Help with home nas/server setup
vinaypro
I have couple of old devices with and looking to replace my NAS(netgear R102) with x86 setup nas/server.
It might be overkill for type-1 virtualization but i would want to try it.
Questions
  1. What is your budget?
    • 20K
    • Monitor - Dell U2311H
    • PSU - Corsair TX850
    • HDD - 2 x500 gb , 1 x2 TB, 1 x4 TB
    • All the above
    • CPU - Suggest - xeon or latest skylake
    • Motherboard - Suggest - any compatible motherboard
    • RAM - Suggest
    • Yes, will upgrade the following within 12 months
    • RAM to 32GB
    • Maybe the CPU for more cores
    • PCIe switch card
    • Bangalore
    • Open to online purchase
    • Yes
    • Running multiple VMs, proxmox,many linux OS, learning/experimentation purposes
    • HTPC
    • Download rig, 24x7 operation
    • NAS
    • None
    • NA
    1. Desktop - 1440x900
    • No
    • Proxmox VE
    • linux, windows over hypervisor
    • Steam OS( Only if possible for trial purposes- not a requirement)
  • CPU - Intel Core i3 6100 -9000,
  • Motherboard - Gigabyte B150M-D3H -7500,
  • RAM - G.Skill RipJaws V 8GB 2133Mhz DDR4 -3500.
  • TOTAL -20,000.
  • TOTAL -20,000.
>>> Thanks.. It is my understanding that these(B,Q,H &Z) mb dont support xeon's like the few of x58 motherboard did..
you could look into unraid. Factor that into cost as well. look up videos of unraid and linustechtips on youtube
I thought unriad was Freenas substitute but on checking further it more than that.. will diffidently try it out.. infact i plan to try all hypervisors..
