Graphic Cards Graphic Card for my PC for 12k
Questions
  1. What is your budget?
    • 12000 INR(Max.)
    • CPU - Intel i5-2500k @4.3GHz.
    • Motherboard - intel extreme DP67BGB3 .
    • GPU - Asus Nvidia GT210 .
    • RAM - G.skill Ripjaws 2x2 GB @ 1632Mhz (1600 MHz).
    • Monitor - Samsung SyncMaster SA300 @ 1920 x 1080p.
    • PSU - 500 W
    • (please mention the rest in above format)
    • All Except GPU.
    • GPU - ASUS GTX 750 ti OC 2GB
    • I WILL UPGRADE RAM TO 8GB IN FUTURE.
    • Lucknow Or
    • Online (preferable)
    • No
    • Gaming
    • Browsing
    • Desktop Processing
    • Watching HD movies
    • No such Preference .But will go for trusted brands like Asus etc.
    • Strategy - Civilization 4
    • Racing - Grid at medium to high settings
    • Call of Duty: Advanced Warfare
    1. Gaming - 1920 x 1080 p
    2. Desktop - 1920 x 1080 p
    • Yes.
    • Windows 7 64 bit
    • Windows 8.1 64-bit pro.
