Gigabyte X99 SOC Champion Review
Today we are having a look at an Overclocking focused X99 motherboard offering from Gigabyte, the X99-SOC Champion.
Gigabyte X99 SOC Champion comes with some top notch feathers for stable and higher overclocking, like 8 phase digital VRM with server grade chokes, long life durable black capacitors and a special OC Socket (2083 Pins) for added CPU Stability. The CPU Socket, Memory Sockets and even the PCIe x16 Slots are plated with 30 microns of Gold (double the industry standard on high end motherboards).A great overclocking board in a budget price, what else an overclocker wants.
Now let’s see what this Intel X99 chipset based board have for us.
Package
Looking at the front of the box, we see gigabyte logo with OC F1 car graphics and motherboard model no. At the rear of the box, we find that Gigabyte goes into great detail on the specifications of the motherboard.
Inside the box
Looks
Board is a solid build in a black and Orange colour theme.
Features
Specifications
Layout
Detailed layout of board.
1. Intel LGA2011-3 / OC Socket (2083 Pins) supporting New Intel® Core™ i7 Processor Extreme Edition.
2. 4 x DDR4 DIMM sockets supporting up to 32 GB of system memory with XMP up to 3400MHz
3. ATX Power connector (24-pin EATXPWR)
4. 13. Exclusive OC Buttons to help enthusiasts and overclockers not only get the most performance from their hardware, but also the absolute most enjoyable OC experience.
5. 6. ATX CPU Power Connector(4-pin ATX12V) & (8-pin ATX12V_2x4).
7.OC PEG adds auxiliary power to the PCIe slots of your motherboard, improving system stability in extreme configurations. This is especially useful in power-hungry 4-way graphics configurations.
8. Back Panel Connectors - 1 x PS/2 keyboard port, 1 x PS/2 mouse port, 4 x USB 2.0/1.1 ports, 4 x USB 3.0/2.0 ports, 1 x RJ-45 port, 1 x optical S/PDIF Out connector, 5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Line In, Line Out, Mic In)
9. 10. 11. 12. 24.1 x CPU fan header, 1 x water cooling fan header (CPU_OPT), 3 x system fan headers.
14. 1 x SATA Express connector, 10 x SATA 6Gb/s connectors
15. M.2 Socket 3 connector. Thanks to the unique design from the X99 chipset, 4 PCIe (Gen.2) lanes can be allocated to the M.2 socket, unlocking up to 20 Gb/s of bandwidth. Turbo M.2 offers considerably faster storage performance than current mSATA and even SATA Revision 3 (6Gb/s) storage devices.
16. Realtek ALC1150 115dB SNR HD Audio
17. Intel x99 Chipset cooled with Solid aluminum and copper heat-pipe heatsink.
18. . Front panel Audio connector and S/PDIF Out header.
19. Thunderbolt™ add-in card connector and OC Panel connector (for future expansion).
20. 21. Serial port and USB 2.0 Connectors.
22. 23. Front USB 3 Port. Connector and System Front panel Connector.
25. Expansion Slots.
GIGABYTE X99 motherboards feature a unique PCI Express design that utilizes 100% of all 40 lanes from the CPU when in a 4-Way or 3-Way graphics configuration. Standard designs limit all 4 main PCIe lanes to x8 (64Gb/s) bandwidth, but thanks to the onboard external clock generator combined with the direct connection of one of the x16 lanes to the CPU (switchless design), GIGABYTE X99 motherboards can unlock the full bandwidth available and provide the best graphics bandwidth possible to the user.
Removing Heat-sinks
Component Layout
Let’s now see what all components Gigabyte have planned for this board.
1. 2. 8-phase digital power, server level Cooper Bussmann chokes coils and Durable Black solid capacitors. IR3580 is IR (International Rectifier) 8-phase single output PWM Controller IC. IR3556M (Integrated PowIRstage) is a synchronous buck gate driver co-packed with a control MOSFET and a synchronous MOSFET with integrated Schottky diode with output current capability of 50A DC each.
3. 4. Two 2-Phase digital memory power supply section (separate for each side DIMMs). IR 3570A is IR (International Rectifier) Dual output 4+1 and 3+2 phase PWM Controllers. IR 3553M is a synchronous buck gate driver co-packed with a control MOSFET and a synchronous MOSFET with integrated Schottky diode with output current capability of 40A DC each
Back side of the board have four POSCAP Tantalum-Polymer Capacitors for each side DIMMs.
5. 12.Fan control ,Voltage monitoring and managing Debug display is performed via ITE IT8792E the system controller.
6. 7. Array of Switching MOSFETs and RT9018B chips are a high performance positive voltage regulator for memory voltage reference and tweaking control.
8. Renesas Electronics YET-D720210-0004 Usb 3.0 4-Port Hub Chip.
9. Intel X99 Express Chipset.
10. Gigabyte uses two SPI chip labeled MXIC MX 2SL12873F a capacity of 128 Mb for storing UEFI BIOS.
11. ITE IT8620e is SuperIO chip monitors temperatures, voltages and other key metrics for normal operation and overclocking.
Package
Inside the box
Looks
Features
- Supports New Intel® Core™ i7 Processor Extreme Edition
- Support for DDR4 XMP up to 3400MHz
- Genuine All Digital Power Design with IR Digital PWM & IR PowIRstage® ICs
- Exclusive GIGABYTE OC Features
- Server level Chokes
- Gold Plating for CPU socket, Memory DIMMs and PCIe slots
- Extreme 4-way SLI™ and CrossFire™ support
- Turbo M.2 connector for up to 20 Gb/s data transfer
- SATA Express support for 10 Gb/s data transfer
- Intel gaming networking
- 2x copper PCB design
- Realtek ALC1150 115dB SNR HD Audio with Built-in rear audio amplifier
- Long lifespan Durable Black™ Solid caps
- APP Center including EasyTune™ and Cloud Station™ utilities
- Thunderbolt™ Ready
- GIGABYTE UEFI DualBIOS™
Specifications
Layout
Removing Heat-sinks
Component Layout
