FS: RAM G.Skill Ares DDR4 32Gb 3200MHz CL14 1.35V @ 28000/-
aasimenator
MCITP 2008
Reseller
Greetings,
Product Model Number: F4-3200C14Q2-64GAK
Memory Type: DDR4
Capacity: 32GB (8GBx4)
Multi-Channel Kit: Quad Channel Kit
Tested Speed: 3200MHz
Tested Latency: 14-14-14-34
Tested Voltage: 1.35v
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
SPD Speed: 2133MHz
SPD Voltage: 1.20v
Fan lncluded: No
Height: 33mm / 1.30in
Warranty: Limited Lifetime
Features: Intel XMP 2.0 (Extreme Memory Profile) Ready
To those that have noticed already and those that have not... this memory is part of a 64GB kit but I've only got 32Gb ( 8GBx4) as part of an upgrade I needed to perform on a server but were never used.
These memory stick information will not be available online anywhere, the details were provided directly by G.Skill support that these are system integrator kits.
Usually memory kits have lifetime warranty but since I don't have an invoice warranty is void, but memory sticks are very less likely to fail in a system these days. will provide 7 days testing warranty as long as no physical damage has occurred.
[DOUBLEPOST=1526390534][/DOUBLEPOST]bump.....
