Hello,
I use a 3g usb dongle as a backup connection on the router. The 3g kicks in when the BSNL broadband has died. I would like to limit my connections when the 3g interface is being used. The idea is to use a script to find out when 3g is being used and then act accordingly.
Unfortunately, i havent been able to figure out the 3g status from command line. The following is what the modem provides.
Code:
telnet 192.168.1.1
Trying 192.168.1.1...
Connected to 192.168.1.1.
Escape character is '^]'.
username:admin
password:*****
Authenticate Success!
TBS>>help
Input "?" to get the help information,
Input "cm xxx" to change you command mode to xxx,
Input CTRL+C to interrupt the command input
Now list the command word of all mode:
Mode:Global
3g display the brand,design,firmware don...
acl acl: <conname(s)> <contype(s)> <port(...
adsl Display the table SNR or Bits per ton...
cls Clear screen
cpuinfo CPU usage
ddns Show or config the ddns module
debug Get or Set a Node,only for debug
device display the brand and model of proces...
dhcpserver Show or config or enable or disable t...
dmz Show or configure the DMZ
exit Logout from the system
firmware download image via network using TFTP...
help Help information of command line operate
ifconfig Show or configure the WAN interface
ipt Show or configure the IPT module
lan Show or config or enabl or|disable th...
mac Show or config or enable or filter ma...
meminfo Memory usage
modem display the brand,model,firmware vers...
natp Show or config the natp(Port Forwardi...
password config the username and the password
pmirror pmirror vpi [vpival] vci[vcival] flag...
reboot reboot
restore_defaults load default factory config
route Show or config the route module inclu...
save save config
save_and_exit save config and exit
save_and_reboot save and reboot
set scroll Set screen scroll mode: manual or aut...
sh go to shell platform
wan Show or config the wan connection
wlan Show or config or enable or disable t...
wmac Show or config or enable or filter wi...
Mode:Root
Mode:Config
TBS>>
