Budget 71-90K Best config for Maya 2016
craig22
Recruit
Hello
Kindly give me the best best pc config for smooth functioning for maya 2016, i'll be buying intell board and processor and nvidia graphic card windows 7 . Kindly give me the detailed congid for destop cpu only i have a dell monitor and my budget is Rs.75000 Thank you
Sorry mate i didnt get you in the above quote.
My budget is Rs.75000
Rest i dont intend to upgrade i intend to buy a new rig/config
I dont want to do gaming
I am not interested in buying online
I am from Mumbai
Intel Board and processor and nvida graphic card
Windows 7 sp1
Want an excellent rig with that budget for maya 2016 smooth functioning
Budget - 78.4k
Processor Intel Xeon E3 1245 v3 21,000
Motherboard
Gigabyte GA-H97-D3H 8,000
Memory
Kingston HyperX Fury 16GB(4GBx4) 1600Mhz 6,600
SSD
Samsung 850 Evo 250GB SSD 8,500
Graphics Card
LeadTeak Quadro K620 2GB DDR3 13,500
Power Supply
Antec VP550P 4,000
Cabinet
Corsair SPEC-01 3,500
Internal Storage
WD Caviar Blue 1TB HDD 3,500
Monitor
Dell S2216H 22" LED IPS 9,000
KB/Mouse
Logitech MK200 800
Total
- 78,400.
Spend 5 grand more and get a Quadro K620. Unless you use Viewport 2.0, lots of stuff doesnt work correctly on a Geforce card.
Case Cooler Master HAF 912 Combat
Processor Intel Core i5-6600K
Motherboard MSI Z170A GAMING M3
RAM G.Skill Ripjaws 4 series 16GB (2 x 8GB) DDR4 2400Mhz
AIO Liquid Cooling Kit Cooler Master Seidon 120V Plus
Graphics Card MSI GeForce GTX 960 2GB OC
HDD Western Digital Blue 1TB
Power Supply CoolerMaster B-Series B700 Watt
CPU - Intel Core i5 6500 -14600,
Motherboard - Gigabyte B150M-D3H -7100,
Memory - Corsair Vengeance 8GB 2133Mhz DDR4 -3900,
Graphics Card - Zotac GTX 960 2GB -15500,
Power Supply - Seasonic S12II 520w -4900,
Cabinet - Corsair SPEC-01 -3500,
Internal Storage - WD Caviar Blue 1TB HDD -3500,
Monitor - Dell S2216H 22" LED IPS -9000.
TOTAL -62,000.
TOTAL -62,000.
Replace i5-6500 by i5-4590k
960 by 970
There is a difference between a "gaming" graphics card and a "professional" graphics card. There is a reason why professionals (rendering, animators etc) go for Quadro cards for their workstation usage and why there is a market for these. Besides the OP had made it clear that he won't be gaming.
As for the price one can check with other dealers or see if they can procure it for less.
Slight OT: It is not suggested to upgrade to the R9 380/390 from the R9 2XX because, as many sites have already said, they are rebadged models with minor improvements. So basically if you have an R9 2XX card you can just say "screw the 3XX" and not upgrade it.
