Dude, why are u asking the same question in others threads? You have asked these questions in one more thread if am not wrong. If at all you have a question, post it as a new topic and ppl will reply. As for the answer to ur questions --
Some sites dont work in widescreen mode because when it was created, widescreen was not thought about. Its upto the site admins to give an option for scaling to widescreen. The monitor or you dont have any control over it. Except of course in forums like ours where u r given a bit of control to change the looks by changing the display style. If you still want to have websites optimized for widescreen, then use firefox and install widefox plugin (use google :bleh: to get the download link) but dont ask me if it screws some formatting
For your second question, The color reproduction may not be as good as compared to the other LCDs coz 1912wb-3 is a TN panel. But it is no way a bad one. I have the same monitor and the only thing you need to do properly is the LCD screen calibration to make the colors look good. ofcourse ur viewing angle should also be considered coz its a TN panel. The videos and everything looks almost the same. The only problem with ur TN panel is when u r doing the photoshop work.
