hello friend ,:cool2:
am building the following thing and dream of my killer ride....
amd phenom ii x6 1055t
gigabyte 890GPA-UD3H
crosair / G.skill ddr-3 ram 2gb on
crosair vx450 smps i think so
but the most difficult thing for me is to think of a good cabinat with good looking body , air cooling and extreme........
plz help me out wit the cabinat and configuration..........
my friend has an gigabyte chaain luxo 142 and i like it :ohyeah:
but want to try some thing different plz help
and those r from mumbai plz if possible , plz provide the above configuration rates to ...
thank you all in advance ........:hap2:
cheers to all who live as a gamer and pc users......:clap:
6 replies to this topic
#1
Posted 28 August 2010 - 01:45 PM
#2
Posted 28 August 2010 - 03:19 PM
Whats your budget for the cabinet???
check out this cabinet, hope you like it NZXT Gamma PC Cabinet Review | Gaurav Live
#3
Posted 28 August 2010 - 03:27 PM
Firstly improve your English then if possible and patient enough use this template to get accurate feedbacks http://www.techencla...use-143714.html
#4
Posted 28 August 2010 - 03:31 PM
NXZT M59,Hades,Lancool K62,NZXT tempest EVo,many more are there depends on your budget.
#5
Posted 28 August 2010 - 05:54 PM
The Cooler Master Elite 430 for 2.7k looks pretty good and has decent airflow if you add an extra fan or two. Gamma seems to be the preferred choice though and it's cheaper.
Like Alpha17 said, follow the template so it's easier to give you advice on your rig.
#6
Posted 29 August 2010 - 05:35 AM
total budget of Rs.25000 but can try to get a little more if the thing is good but not more the rs. 3000 for cabinat
#7
Posted 29 August 2010 - 11:33 PM
25k huh ? no thought of a graphics card ??
Sign In
Create Account
Back to top
