Jump to content
Power Sockets Issue
3 replies to this topic
#1
Marc2
Guys,
Please help me out with this.
I have:
1. Belkin Economy power strip
2. APC 550VA UPS
Should I connect the power strip to the wall socket and plug in the UPS to the strip's socket? [ Mains -> Strip -> UPS ]
Or should I plug in the power strip to one of the two UPS sockets? [ Mains -> UPS -> Strip ]
Any reasons?
The problem is that I need sockets for: modem, speakers, monitor and CPU. The APC UPS has only two sockets at the back (if I'm not wrong).
#2
HailStonE
Use following only...
Quote
If you connect Strip to UPS then unnecessary load will increase.. I am myself using same config for my APC UPS since last 3 years...
Though UPS manufacturers recommend UPS to be connected directly to mains, its not always possible with so many peripherals & only one power socket.. I would recommend to use output (Mains) with at-least 16Amps rated & then you can connect Strip --> UPS..
#3
NAV33N
^well my setup is also a bit same..
it's like Power--->Extension--->UPS..
using it for last 9 months & is working like a charm..
even i'm having APC 650VA UPS & i've connected my speakers to Surge Protection only.
@OP just connect monitor & CPU to UPS & rest of the stuffs to the surge protector..
#4
Marc2
Thanks HailStonE and naveen58. I'll take your advice and do the same.
