Lian-Li launches a couple of new cases for their 2010 lineup.
The best thing is, they all feature the soon-to-be standard, USB 3.0 (backward compatible with 2.0 of course).
Will post pics and specs of cases as and when i get an OK from LL. Till then here are the new cases that are already announced.
Lian-Li PC-A77F All Aluminum Full Tower
Specs
[table]Model | PC-A77F
Case Type | Full Tower
Dimensions | (W) 220mm x (H) 572mm x (D) 590mm
Front bezel Material | Aluminum
Color | Black, Silver
Side Panel | Aluminum
Body Material | Aluminum
Net Weight | 9.2KG
5.25" drive bay (External) | 12
3.5" drive bay (External) |
3.5" drive bay (Internal) | 9 (Use 5.25 x 6 Bays)
Expansion Slot | 8
Motherboard | E-ATX / ATX / M-ATX/ CEB
System Fan (Front) | 120mm Blue LED Fan x 3 (1200RPM)
System Fan (Top) | 140mm Fan x 2 (1000RPM)
System Fan (Rear) | 120mm Fan x 1 (1500RPM)
I/O Ports | USB3.0 x 4 / e-SATA x1 / HD+AC97 Audio
Maximum Video Card Size | 365mm[/table]
Lian-Li PC-8FU All Aluminum Mid-Tower
Specs
[table] Model | PC-8FU
Case Type | Mid Tower
Dimensions | (W) 210mm x (H) 460mm x (D) 490mm
Color | Black / Silver / Red (Spider Edition)
Side Panel | Black, Silver / Aluminum Red (Spider Edition) / Spider Transparent Side Panel
Net Weight | 5.85KG
5.25" drive bay (External) | 3
3.5" drive bay (External) | 1(use one 5.25 to 3.5 converter)
3.5" drive bay (Internal) | 6
Expansion Slot | 8
Motherboard | ATX / M-ATX
System Fan (Front) | Black / 120mm Blue LED Fan x 2 (1200RPM) Silver / 120mm Fan x 2 (1200RPM) Red (Spider Edition) / 120mm Red LED Fan x 2 (1200RPM)
System Fan (Top) | none
System Fan (Rear) | Black / 120mm Fan x 1 (1200RPM) Silver / 120mm Fan x 1 (1200RPM) Red (Spider Edition) / 120mm Red LED Fan x 1 (1200RPM)
I/O Ports | USB3.0 x 2 / e-SATA x1 / HD+AC97 Audio
Maximum Video Card Size | 285mm[/table]
BTW, we are the first distris in the world to order USB 3.0 cases :) So Yipppeeeeeeeee
Sign In
Create Account
Back to top
