Hello experts,
If I want to change the wheel size from 14" to 15", how to calibrate the speedo and odo ? Will the dealer can do it easily?
regards,
Anand
13 replies to this topic
#1
Posted 15 December 2009 - 03:17 PM
#2
Posted 15 December 2009 - 04:24 PM
Speedos are set to show a higher speed than you are actually travelling. By increasing the wheel size, your speedo will show a slightly lower value than before which will, in fact, be more accurate than what it is currently showing. So I would recommend that you dont calibrate anything and enjoy the increased accuracy.
If you do decide to have it calibrated anyway, please let me know where you finally ended up having it done.
#3
Posted 16 December 2009 - 04:22 AM
So overal ODO will be wrong only. Total distance travelled will be much higher than the ODO. So I think this must be corrected.
And the error in Speedo and ODO is normal.
#4
Posted 16 December 2009 - 05:27 AM
You have the science all wrong.
When you increase from 14" to 15", the tyre profile reduces(or it should reduce, if you upsize properly). So, the rolling circumference of the tyre remains the same anyway.
#5
Posted 16 December 2009 - 07:24 AM
For argument's sake, I'm ignoring tireboi's valid comment.
The change in speed due to the diameter increase is proportional to the ratio of the diameters. D2\D1 = 15/14 = 1.0714
This is a 7% increase in speed for the same RPM of the tire\engine.
Stock ODOs have an inbuilt error of around 5-10% (possibly even higher in bikes). The tire change will, therefore, show you a more accurate speedo reading.
#6
Posted 16 December 2009 - 10:54 AM
Sorry to be pedantic, but it's TYREBOI. We're followers of the Queens English, right? :P
#7
Posted 16 December 2009 - 11:40 AM
So here, even the rim size increases, the tyre radiaus remain the same? If yes, why somebody increase the rim size?
#8
Posted 16 December 2009 - 11:41 AM
Check out this Tyre size calculator!
It shows ODO and speedo errors depending upon the upgrade from stock wheels - Tire Size Calculator - tire & wheel plus sizing
Some other "Must Read" info - Car Bibles : The Wheel and Tyre Bible Page 1 of 2
#9
Posted 16 December 2009 - 12:54 PM
Reasons for increasing rim size - looks and performance. In India only the former is valid ;)
#10
Posted 16 December 2009 - 01:02 PM
The best way out is to put a GPS in your car and then write down the real values of speed difference in the GPS and the cars speedo and odo.
then make a mental note of it and you will be fine after some time. it will get into your habit.
#11
Posted 16 December 2009 - 01:48 PM
There is a tyre size calculator here
www.tyrebibles.com
Plan your upgrade accordingly
www.tyrebibles.com
#12
Posted 17 December 2009 - 05:00 AM
I decided not to change the tyre. The steel will be replaced with alloys.
But again there is some complications. alignment of the hub and the alloy centre postions......Normally this will be equal to existing steel rim?
#13
Posted 17 December 2009 - 05:29 AM
Forgive my insolence m'lord :)
#14
Posted 20 December 2009 - 06:16 AM
my new vehicle wheels are 185x60x14 82T. What is 82 T here? Is this offset?
I checked with one dealer in JC road. He got Eva brand. Are they good?
Sign In
Create Account
Back to top
