Which PSU will save more electricity bills while running 24/7 downloading?
Cooler Master Real Power Pro 460w / Corsair VX 450 / Gigabyte 460w
Started by Anubis, Dec 07 2009 05:50 PM
23 replies to this topic
#1
Posted 07 December 2009 - 05:50 PM
#2
Posted 07 December 2009 - 05:57 PM
All of them almost will do the same thing cause if I recall correctly, they are all 80+ certified. Just that vx450 will give you more room just in case you decide to upgrade your download rig to make it a partial gaming rig
#3
Posted 07 December 2009 - 06:02 PM
No it will not be gaming at all.
U sure all will be same?
#4
Posted 07 December 2009 - 06:14 PM
Go for the seasonic 380w. The load on a SMPS must be in the sweet spot ie., 30-70% of its capacity for it to be fully efficient(80+). So going for a low power SMPS will be more sensible for a DL rig.
#5
Posted 07 December 2009 - 06:20 PM
Well don't have Seasonic PSU in Kolkata
Can you help me between the choices bro?
#6
Posted 07 December 2009 - 06:24 PM
you can get one from the dealers here on TE
#7
Posted 07 December 2009 - 06:31 PM
This will be for my friend
He won't buy online
Please guys can you help me with my choice
I know i sound desperate and annoying but i really need some advice on this
#8
Posted 07 December 2009 - 06:35 PM
The most efficient one.
Given the same rig, you have to look at the efficiency figure at the power draw of that rig.
For a low-power rig, say around 100 watts, the VX450 is about 85% efficient, which means a total power consumption of 117 watts.
At the exact same power draw, a Coolermaster Extreme 400 is 75% efficient (approx), based on the behardware review, and the Gigabyte around 82%.
The CM will thus draw around 133 watts from the socket, and the Gigabyte 121 watts.
The difference between the worst and best supplies is only 16 watts, and between first and second place just about 5 watts. Over a 24-hour, one month run that is 11.5 (3.6) units, or about 17 (5) rupees/mo.
However note that the decreased efficiency also results in higher heat output from the PSU, and low quality PSUs have other issues which are well covered in past threads. Ultimately the differences in efficiency come from conscience, not from the wallet. That little bit you save helps overall conservation, so you should get the most efficient supply your pocket permits.
#9
Posted 07 December 2009 - 06:36 PM
Then get a Corsair CX 400.
#10
Posted 07 December 2009 - 06:39 PM
yes get a Corsair CX400
#11
Posted 07 December 2009 - 06:40 PM
CX 400 was quoted 3.8k by Arihant and Vedant
#12
Posted 07 December 2009 - 06:48 PM
#13
Posted 07 December 2009 - 06:49 PM
#14
Posted 07 December 2009 - 06:53 PM
i use mercury 300W for my 24/7 downloading rig, P4/2.4GHZ, 845GEBV2 Mobo, 1 80MM FAN
#15
Posted 07 December 2009 - 06:57 PM
Seasonic S12II-380 Power Supply | silentpcreview.com
Corsair VX 450 ower Supply | silentpcreview.com
Still Seasonic will make a better buy. Better convince your friend for online buy or get a dealer to get it for you.
#16
Posted 07 December 2009 - 08:54 PM
Dude u want a PSU in Kolkatta na at a nice price na chill give me call tomm at around 11pm i'll send u to a place where oyu'l be able to get Corsair CX 400 - 3300/- and Seasonic 380W - 3000/- ok chill now go to sleep and give me call tomm if u want one :)
#17
Posted 08 December 2009 - 03:12 AM
The Seasonic has very similar efficiency to the Gigabyte. Using the Antec EA380 as a proxy (they are identical supplies, only rebadged by Seasonic for Antec), it is a very good buy and competitive with the VX450 for efficiency - though not as cost-effective as the Gigabyte. OTOH, the Seasonic will have better build quality than a Gigabyte.
For those suggesting the CX400, note that its efficiency is lower than all the other candidates mentioned here apart from the CM, it is only about 81% efficient at 100 watts load. The difference is marginal, but between that and the Seasonic/Gigabyte I'd take the Seasonic. Or if the budget was really tight, the Gigabyte.
#18
Posted 08 December 2009 - 04:40 AM
As we discussed earlier Seasonic 380W hands down!! call Rahul, get it, close thread!
#19
Posted 08 December 2009 - 04:52 AM
Corsair VX 450 - 3.7k (Vedant)
Actually, yesterday they said they didn't have it but will get it today
It was a hard deal to let down .
Thank you cranky , Rockfella , Karthi007, stalker , saqib_khan , etc
Big thanks to Udit , TheITWares(Rahul) for helpiing me out.
Thank you guys
Really I Thank you very much from the deepest core of my heart
Oh yeah TheITWares(Rahul) i will visit your shop pretty soon. Give me your no
Still update to go TX 750 or TX 650. Once i decide by today, MODS may close this thread
Thank you everyone for helping me out guys
Thank you guys
#20
Posted 09 December 2009 - 09:24 AM
Good price but SS 380 wud've been a better PSU for 24x7 downloading on the other hand u got 5 years peace of mind and headroom if u want to run a heavy gpu in the future ;)
Thank you guys
Thank you guys
Sign In
Create Account
Back to top
