will get it in couple of days
1. Q: What is your budget?
1.as low as possible (around 13k my uncle doesnt want to spend much on his daughters pc)
none
n/a
anything ( cost as low as possible)
this is for a cousin of mine she is studying engg ( so never mind)
hyderbad
no
1. day to day activity
2. programming
3. browsing
none
0 gaming
11. Q: What is your preferred monitor resolution for gaming and normal usage
no pref
no
1. Windows xp
2. May be windows 7 ( only if i can)
Thanks for the replies guys( anubis, karthik007 and saqib_khan). as i want a low cost one better to go with amd. any other way to reduce cost other than going with atom.( will find out about the crt, will ask him if crt is ok)
Processor: AMD Sempron 140 - 1.8k
Motherboard: Asus M2N68-AM PLUS - 2.3k
1GB DDR2 800MHz Ram Transcend - 1.1k
250GB HDD Seagate - 1.9k
Cabinet: Low cost mercury/iball/zebronics cabinet w/ bundled 400W SMPS - 1.2k
Optical Drive: L.G. GH22NS30 SATA/Samsung SH-S22F SATA - 1.1k
Monitor: ACER 15.6" - X163 - 4.8k
Keyboard: Samsung Pleomax - .2k
Mouse: Logitech Optical - .4k
Total: 14.8k.
ya i agree with saqib_khan better to skip atom, as it would be used for some programming.
5 replies to this topic
#1
Posted 07 December 2009 - 01:41 PM
#2
Posted 07 December 2009 - 02:00 PM
Intel Celeron 430 - 1.9k
Gigabyte G31ME S2L - 2.4k
1GB DDR2 Ram Transcend - 1.1k
Cabinet: Zebronics Bijli ATX w/ bundled 400W SMPS - 1.7k
Monitor: Acer 17" - AL1776 - 5.7k
Total - 16.4k
Total - 16.4k
#3
Posted 07 December 2009 - 03:12 PM
Total: 14.8k.
If you need to reduce the cost more then the only option is a 17" CRT monitor~3k(NEW) or a old one for 1.5-2k.
By this way you can bring down the cost to 13k.
Total: 14.8k.
#4
Posted 07 December 2009 - 03:15 PM
Under that budget you can go for Atom also. Combo comes for 3K. But I wont recommend that. You can also go for AMD Sempron & VIA Chipset motherboard.
#5
Posted 07 December 2009 - 07:43 PM
guys anymore suggestions or do u guys think the one given by karthik 007 is the best option?......
#6
Posted 07 December 2009 - 07:53 PM
+1 for Karthi007
Very good suggestion
Sign In
Create Account
Back to top
