Jump to content
Mid range multi purpose rig
10 replies to this topic
#1
shuvd
Hey guys, need your help. Will be assembling a multi purpose rig this weekend. Will use it for regular desktop processing, gaming @ 1080 and downloads (24x7). And, I'm totally confused. Don't know what to buy and hence have fixed a budget of about 60k max. Would be delighted if I can get the rig up and about below this.
Gaming would be FPS, racing (NFS et al), etc. So, here goes..
1. Q: What is your budget?
a. 60K
a. CPU - Intel E5200
b. Motherboard - Asus P5KPL-AM/PS
c. GPU – XFX 8500GT 512MB
d. RAM - Kingston 2X1GB 800Mhz
e. Monitor – Ancient Acer AL1714
f. SMPS - Corsair HX620
g. Seagate SATA 80Gb and 1TB
h. LG DVDRW
i. Zebronics Bijli cabby:bleh:
j. Altec Lansing ATP3
k. Logitech Kbd and mouse
a. HDDs
b. SMPS - Corsair HX620
c. Kbd and mouse
a. CPU – AMD Phenom. Confused between X2 and X4. If X2, I would like the 550BE. Would the 955BE be an overkill?
b. Motherboard - any compatible motherboard. DDR2 or DDR3?
c. GPU – 5770 or 5850?
d. Ram depending on mobo
e. 1Tb X 2 HDDs
f. Optical drive (IDE)
g. 22” FullHD monitor. Nothing expensive.
h. Do I need a CPU cooler?
i. El cheappo cabby with enough space and ventilation.
In the next 6 months,
a. XFire if required
b. Sound card – Asus (will connect to my amp for 2 channel)
c. Cabinet – CM/Thermaltake
d. Populate all RAM slots
e. Blu ray writer when prices come down to sane levels.
a. Calcutta
b. Open to online purchase
a. Yes, if under at least 2 yrs warranty
a. Gaming
b. Browsing
c. Desktop Processing
d. HTPC maybe
e. Download rig, 24x7 operation
f. Watching HD movies maybe
a. Don’t want A-Bit, bad experience. Should have good support in Calcutta
a. FPS – high settings
b. Racing - Grid at medium to high settings
11. Q: What is your preferred monitor resolution for gaming and normal usage
1. Gaming – 1920x1080
2. Desktop – 1920x1080
. Should I? Would need step by step guidance from yall
. Windows 7 64 bit
I have mentioned both X2 and X4 CPUs. Would get the one that suits me. I mean just because I've mentioned 955, doesn't mean I want that. If there is a cheaper alternative that serves my purpose, am all ears. Same for all the stuff.
Thanks in advance.
P.S. I have an Xtreamer and would like to stream movies/music from my rig. Which router to get?
bump.. suggestions please people.
#2
shuvd
What, no one?
#3
Anubis
How would you like 2 pcs instead of one ?
Since you would be using the machine 24/7 for downloads you should split your 60k into 2 pcs of budget 21k and 39k resp
One for 24/7 downloading and the other for Pure gaming @ 1080p
Wat say ?
#4
rite
I suggest:
RAM thru KMD
MSI Mobo, and not micro-atx
Less HD space
Cheaper cabinet
Samsung 2350 or 2233sw
#5
Anubis
Because every penny saved in electricity is a penny earned
Total Budget : 60k = 21k +39k
1. Dowmload rig 24/7 - 21k
2. Gaming PC - 39k
Processor: Athlon II X2 240 - 3k
Mobo : MSI 785GM-E51 - 4.6k (DDR3 mobo )
RAM: Transcend 2GB DDR3 1333MHz - 2.6k
HDD: Seagate 500GB SATAII 7200.12 series- 2.4k
Cabinet: Zebronics Bijli ATX - 1.1k
SMPS: Gigabyte 460w - 2.2k
Optical Drive: L.G. GH22NS30 SATA/Samsung SH-S22F SATA - 1.1k
Monitor: Dell 18.5" - E1910 IN - 6.6k
Keyboard: Samsung Pleomax - .2k
Mouse: Logitech Optical - .4k
2. Gaming PC - 39k
Processor: Phenom II X2 550 - 5.1k / Athlon II x4 620 - 5.2k
RAM: Transcend 2x2GB DDR3 1333MHz - 5.2k
HDD: Seagate 1TB ( From previous rig )
Cabinet: CM Elite 310 - 1.5k
SMPS: Corsair HX 620 ( From previous rig )
Monitor: Benq G2220HD 22" - 8k
GPU : ATI 4890 512mb - 11.5k / ATI 5770 1gb - 11k (DX11 futureproof )
#6
dvijaydev46
If you are not more into multi media, video processing, editing and converting, even a 550BE or 720 BE will be just fine.
@Anubis: How do you say an i5 rig costing more than 17K along with really crappy DDR3 will provide more vfm than an AMD rig that may include a 950BE or a cheaper X2 or X3 and TA790GXE which would cost 13K max, in Games, especially when talking about HD gaming?
#7
Anubis
I know i made a mistake and i corrected it with my next post.
See my last post , I made 2 fresh setups of 21k and 39k
One for 24/7 downloading and the other for HD gaming @ 1080p
Now , wat say ?
#8
v.Na5h
hey wats the diff betw using
a GSKill ddr3 1333mhz and a similar transcend/kingston one
@dvijaydev46
why do u call a kingston/transcend ddr3 a crappy one
the price difference is almost 1k for a 4gb kit
is it just about OCing
how much fps difference between the two???
#9
dvijaydev46
^^ Hmm just saw that. But Biostar boards will be far better than MSI boards due to their PCBs. I would ask the OP to get TA790GXE a DDR2 board with 4GB CL5 1066 MHZ RAMs, which will be a cheaper buy, but provide the same performance, if not higher than the DDR3 1333 CL9 Rams.
#10
Anubis
I think DDR3 mobo are the future and going with DDR2 mobo which is equal to a DDR3mobo now is waste if you have the money.
DDR3 rig futureproof
#11
dvijaydev46
@dvijaydev46
Because they are vale DDR3 rams with CL9 cltency which defeats the very purpose of DDR3 (read faster). Whether they are Transcend/Kingston or even G-Skill value rams, they are as said above, CL9 rams which provide no performance benefit over 1066MHz cl5 rams but carry 5.2K per 4gb, whereas you can get better CL4 800MHz Rams or 1066 CL5 RAMs cheaper than that.
Yes the G-Skill rams I've mentioned will be helpful while OCing.
There won't be any performance difference b etween the afforementioned DDR3 and DDR2 RAMs. Good DDR2 RAMs are cheaper than DDR3 value RAMs.
DDR3 maybe futureproof. But even the DDR3 mobos are more expensive than DDR2 boards. What I was saying was, let the OP get a board and RAM good 4gb for today so that he wouldn't have to upgrade his ram in the next few years.
