Jump to content
Attacked pls help
13 replies to this topic
#1
satanheart
I've been infected by the new folder virus. I used avast, nod32 and even norton nothing happens.even my taskmanager has got disabled . I really cant format my complete hard disk i've got 1tb of games and hd movies pls help.
#2
hayabusa_ryu
If u can install .exe then use Kaspersky Internet Security 2010 Trial(update it fully) and run the FULL SCAN. Which OS are you using and what's the name of the virus?
#3
rdst_1
try kaspersky. it did clean out that virus. however from what i have seen this virus doesn't effect vista as much as it does to xp. which os are you using
#4
Migician
Kaspersky Internet Security is the best
#5
axeman
download the latest sdat from the mcafee site, use it to scan full system in safemode.
McAfee, Inc. - Downloads - Virus Protection - DAT Files
#6
dOm1naTOr
ya, kis is the best for curing infected systems, whereas there are lot others which has better prevention.
But once, affected then no other choice than to use KIS.
do as suggested by hayabusa_ryu
it ll do the job.
i have found it better than mc Afee, avast, AVG, bit defender, norton etc.
#7
sam000
Cant he use Gdata bootcd? to heal his infection heard it has twin engine and a very high detection rate:).
#8
satanheart
Using windows7 .anyway thanks guys will get kis and scan the comp
#9
Audiophi1le
if u cant install AV.....use 3rd party process monitoring tool and delete all process which u find suspicious
(having path in Temporary folder, usually)
2nd. Delete all startup suspicous apps(msconfig/3rd party apps)
3rd Now install NIS 2010 trial and do a full system scan.
#10
hellfire
How about trying the Avira AntiVir Rescue System? I understand its a bootable disc to scan the PC without booting Windows off the hard disc...never tried it myself though. Avira AntiVir Rescue System
#11
Uriel
+1 for what Gowt1ham says. There is a small utility known as processexplorer... just google procexp.exe. If the virus restarts when you shut down the process, processexplorer let's you suspend the prorcess, so that it is not closed, but it is not working either. Then you can run some scans, and install software. Backup first!
#12
sato1986
i had a similar experience with new-folder-virus. It disabled all anti-virus programs like nod32, avast..
Dr. Web's CureIt standalone antivirus (trial edition) did wonders n deleted the damn "Khatra.exe" virus. :)
#13
rohan_mhtr
Download and run the latest Dr. Web's CureIt antivirus in safe mode and also dont connect your pc to the net when scanning takes place . The new folder virus disables all antivirus programms and it also monitors all new .exe installations . So do as i said . Dr cureit does not need any installation and it can directly run in the safe mode .
#14
nj_gamer
Run Combofix, will definitely help you... Its one of the best tools for such infections...
Download only from here
A guide and tutorial on using ComboFix
since there are many fake combofix sites out there...
And do post your results...
Regards
