I want to know whether I can play dual player offline on a single PC with Controller and Keyboard. Since RE5 has two characters, I want that one to be operated by me through Keyboard and other to be operator by my friend on controller. In my case, both controller and keyboard controls one character at the same time and the other character remains auto controlled by the computer. Please help in this regard. I am using xbox 360 controller for PC and normal qwerty keyboard for gaming.
Thanks in advance.
Raheel Shadab.
4 replies to this topic
#1
Posted 14 November 2009 - 09:23 AM
#2
Posted 14 November 2009 - 02:59 PM
No you can't. If you're referring to the split screen co-op mode, then it's been taken off on the PC version. Only console versions had that feature.
#3
Posted 14 November 2009 - 07:47 PM
Any other way? patch or update?
#4
Posted 15 November 2009 - 08:03 AM
#5
Posted 15 November 2009 - 12:26 PM
No split screen for pc.
I did play offline co-op with a friend over a LAN connection.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Sign In
Create Account
Back to top
