Jump to content
100% cpu usage.. help
10 replies to this topic
#1
leviathan16
i ran hijack
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 9:14:18 PM, on 11/10/2009
Platform: Windows Vista SP1 (WinNT 6.00.1905)
MSIE: Internet Explorer v8.00 (8.00.6001.18828)
Boot mode: Normal
Running processes:
F:\Windows\explorer.exe
F:\Windows\system32\wbem\unsecapp.exe
F:\Windows\system32\taskeng.exe
F:\Program Files\AIMP2\AIMP2.exe
L:\regsvr.exe
L:\regsvr.exe
L:\regsvr.exe
F:\Program Files\WinRAR\WinRAR.exe
F:\Program Files\eLitecore\Cyberoam Client for Corporate\CyberoamClient.exe
F:\Program Files\Mozilla Firefox\firefox.exe
E:\lan msgnr.exe
F:\Users\poiu\AppData\Roaming\Google\Google Talk\googletalk.exe
F:\Program Files\Internet Download Manager\IDMan.exe
F:\Windows\system32\taskmgr.exe
E:\New Folder (2)\firefox-ultimate-optimizer-11\Firefox Ultimate Optimizer.exe
F:\PROGRA~1\FOXITS~1\FOXITR~1\FOXITR~1.EXE
F:\Program Files\DC++\DCPlusPlus.exe
F:\Windows\system32\SearchFilterHost.exe
F:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = 127.0.0.1:8080
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local;<local>
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O2 - BHO: IDM Helper - {0055C089-8582-441B-A0BF-17B458C2A3A8} - F:\Program Files\Internet Download Manager\IDMIECC.dll
O2 - BHO: IEVkbdBHO - {59273AB4-E7D3-40F9-A1A8-6FA9CCA1862C} - F:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\ievkbd.dll
O2 - BHO: Java™ Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - F:\Program Files\Java\jre6\bin\jp2ssv.dll
O4 - HKLM\..\Run: [RtHDVCpl] RtHDVCpl.exe
O4 - HKLM\..\Run: [AVP] "F:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\avp.exe"
O4 - HKCU\..\Run: [Serv] C:\WINDOWS\system\SYS.VBS
O4 - HKCU\..\Run: [Servk] C:\WINDOWS\system\SYST.VBS
O4 - HKCU\..\Run: [IDMan] F:\Program Files\Internet Download Manager\IDMan.exe /onboot
O4 - HKCU\..\Run: [Msn Messsenger] F:\Users\poiu\AppData\Roaming\regsvr.exe
O4 - HKCU\..\Run: [Yahoo Messsenger] F:\Users\poiu\AppData\Roaming\support\svchost.exe
O4 - HKLM\..\Policies\Explorer\Run: [Mpk.exe] F:\Program Files\KGB\Mpk.exe
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
O8 - Extra context menu item: Add to Banner Ad Blocker - F:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\ie_banner_deny.htm
O8 - Extra context menu item: Download all links with IDM - F:\Program Files\Internet Download Manager\IEGetAll.htm
O8 - Extra context menu item: Download FLV video content with IDM - F:\Program Files\Internet Download Manager\IEGetVL.htm
O8 - Extra context menu item: Download with IDM - F:\Program Files\Internet Download Manager\IEExt.htm
O9 - Extra button: Web traffic protection statistics - {1F460357-8A94-4D71-9CA3-AA4ACF32ED8E} - F:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\SCIEPlgn.dll
O13 - Gopher Prefix:
O17 - HKLM\System\CCS\Services\Tcpip\..\{30B79543-81C4-45F9-905D-0D44B1CFAD1B}: NameServer = 192.168.1.250
O17 - HKLM\System\CCS\Services\Tcpip\..\{41D0C259-8477-4D70-90AF-08F94D78DD04}: NameServer = 192.168.1.250
O17 - HKLM\System\CCS\Services\Tcpip\..\{E66083A9-CB3B-4507-A9A5-AD4F980E729C}: NameServer = 192.168.1.250,192.168.1.253
O17 - HKLM\System\CS1\Services\Tcpip\..\{30B79543-81C4-45F9-905D-0D44B1CFAD1B}: NameServer = 192.168.1.250
O20 - AppInit_DLLs: F:\PROGRA~1\KASPER~1\KASPER~1\mzvkbd.dll,F:\PROGRA~1\KASPER~1\KASPER~1\mzvkbd3.dll,F:\PROGRA~1\KASPER~1\KASPER~1\adialhk.dll,F:\PROGRA~1\KASPER~1\KASPER~1\kloehk.dll
O23 - Service: Adobe LM Service - Adobe Systems - F:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Kaspersky Internet Security (AVP) - Kaspersky Lab - F:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\avp.exe
O23 - Service: FLEXnet Licensing Service - Acresso Software Inc. - F:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: ServiceLayer - Nokia. - F:\Program Files\PC Connectivity Solution\ServiceLayer.exe
End of file - 4447 bytes
plz help!!! its become uselessly slow...
and yes.. i dont switch off the pc for days... can this also be a cause for slowness...
#2
broadway
post a screenshot of your task manager
eg:
Posted Image
#3
ISHROCZ_14
regsvr.exe :\
#4
ultra vires
^^ for windows registry services.
#5
salman8506
it's a virus and the cause of 100% cpu usage scan with a good antivirus. or download trojan remover trial it should take care of it. This link should help http://amiworks.co.i...toruninf-virus/
#6
MohitPreet
format and do a clean windows install
simple!!
#7
hybrid black
is ur proccy a single core or a dual core???
did u try 2 restore ur pc to an earlier point before the problem started??
run the pc is "safe mode" if it still shows 100% cpu usage then do a recovery it not uninstall the 3rd party software from programs and features
also type "msconfig" in start search , go to "startup" in sys configuration and disable every thing execpt little things like sidebar etc(all is better)
then in "services" "hide microsoft services" disable the services that u do not need and then hit ok then restart...hope u already ran ccleaner..all da best:hap2:
#8
yadusaiyan
100% usage is definitely bcause of a virus .Format and do clean installation.
Also get the new kasperskyIS 2010 which cost around Rs5xx(3 user license) IF u dont have one.:hap2:
#9
Spartacus
Well lemme check your Log
It seems that you don't use an anti-virus scanner or your scanner is not active. Only an anti-virus scanner can protect you against new viruses.
I couldn't detect any active process of a firewall on your system. Possible reasons:
(1.) You are using the windows firewall or a hardware firewall.
(2.) You are using a firewall of an unknown vendor.
(3.) You are using a firewall, but for unknown reasons it is disabled
(4.) You don't use any firewall at all.
I recommend you to use a firewall. Download and install one or activate windows xp´s own one. In case you got questions or you want us to add the firewall you use to our database.
#10
amol_cool
Virus Virus Virus! Time to get a good AV.
#11
Rockfella
Not everyone is vellah likeu and me :rofl:
+1, 10 chars, i second that!
OP: Try combofix, download HIREN BOOT CD, every geek should have this!
simple!!
