Jump to content
REVIEW : Beta Brainwavz Pro IEMs.
37 replies to this topic
#1
FaH33m
Introduction :
There was a time I had no idea what IEMs were, and the stock earphones of my Ipod were enough to please my ears .Then came the EP-630 Group Order on TE . Back then the change in sound quality was huge and I instantly fell in love with them. I never knew anything could sound better, but then I was curious and couldn't even resist trying out some other IEMs like PL-30's by Sound Magic ,Head Direct's RE-2 and a few others.
All this while I've learnt that, Sound is very subjective and you can never have the best with audio gear .It just keeps getting better and better each time. Now most of the time I find my IEMs either deeply plugged into my ears or hanging around the neckline of my Tees. I found myself a new love, hobby and passion-Trying out different IEMs and audio-gear.
Today I have the opportunity to review " Mp4 Nation's Beta Brainwavz Pro IEMs" presented to me by Raz from MP4 Nation.
Posted Image
[BREAK=Specifications]
Specifications :
Though specifications don't really mean a lot ,just thought of listing them down.
·[FONT="] Driver: 11mm CCAW (copper-clad aluminum wire) dynamic driver [/FONT]
[FONT=Symbol]·[/FONT][FONT="] Impedance: 24 Ohm (+/- 20%) @ 1kHz [/FONT]
[FONT=Symbol]·[/FONT][FONT="] Sensitivity: 110dB @ 1mW [/FONT]
[FONT=Symbol]·[/FONT][FONT="] Frequency response: 8Hz – 28kHz [/FONT]
[FONT=Symbol]·[/FONT][FONT="] Rated Input Power: [/FONT][FONT="]10mW[/FONT][FONT=Symbol]·[/FONT][FONT="] Max Input Power: [/FONT][FONT="]40mW[/FONT]
[FONT=Symbol]·[/FONT][FONT="] Cable: 125cm, Y-style, 45° angled 3.5mm gold-plated plug[/FONT]
[BREAK=Packaging and Accessories]
Packaging and Accessories :
The earphones were shipped by Mp4 Nation from Hong Kong and I got it within a week. Even though this was a testing sample , I was amazed to find that Mp4 Nation had actually sent me a complete retail package. The box is infact one of the best I've ever seen and feels like the IEMs are of mid-high end segment . It has a sleek black pull out and another Black box which opens up to display the earphone on left side and some other accessories in the right side section. It would implicitly leave a good impression when kept in a shop for display .
Here is a list of accessories supplied with the earphones.
>> on the left side of the box along with the earphones we have.
*4 pair of eartips (2 straight cones,1 bi-flange and a pair of foams/sponge tips )
* a shirt clip (detachable)
* metal filters.(which change the sound slightly, more details in the next section)
>>On the right side when you open the box you can find
* a soft red velvet pouch by Mofi
* 2 clip like cable winders.
The bevy of accessories provided alongside the earphones with a black box en suite provides for a lucrative deal. It surely would have been a plausible experience had they been endowed with a few more ear tips like the normal S/M/L ear tip.
I would rate the overall package and set of accessories as 8/10.
(Recently I heard from Raz @ MP4 Nation that they have added 3 more foam tips and earphone gliders as a part of the accessories now . Infact they are shipping it free to all the people who have ordered it before. I will be getting mine soon and will add a follow up once I try them out.)
Packaging :
Posted Image
Posted Image
Posted Image
Posted Image
The Accessories.
Posted Image
Posted Image
Filter Tips and the Bi-flanges.
Posted Image
Cable Winder Clips.
Posted Image
Metallic Filters.
Posted Image
Different eartips.
Posted Image
From L to R : Transparent Bi-flanges,Orange straight cones,Transparent straight cones, Foam Tips.
Posted Image
Mofi velvet Pouch.
Posted Image
Shirt Clip
[BREAK=Design and Build Quality.]
Like most other earphones the Beta Brainwavz are made up of plastic which seems to be of formidable quality and has a black glossy finish to it . The upper half is shaped like an egg and in the centre it has a small silver emboss with the channel code printed on it . Also you can see small vents surrounding the small circle which I suppose are for better bass extension.
The lower part of the earphones which has the nozzle for the eartips is made up of aluminum alloy and has threading for the filters to be screwed on (More on that later).
If you notice closely you can see that the nozzle for the eartips is longer than most other IEMs with an augmenting diameter. So the ear-tips of most other IEMs wont fit easily.(Fitting the RE-2s bi-flanges took some efforts )
The cable of the earphones is quite soft and thin, yet strong. The crowded Mumbai Local train journeys will vouch for its durability. The place where the cable enters the earphone piece has been covered with an additional layer of transparent plastic since it is most vulnerable to damage. The 45 ° angled 3.5mm connector like most earphones is gold plated.
Overall the Build Quality seems to be really good & on par with most earphones, would rate it as 8.5/10.
The earphones were a bit dirty when i clicked the snaps . so please bare :ashamed:
Posted Image
Posted Image
With and without the filter.
Posted Image
Posted Image
Posted Image
Posted Image
[BREAK=First Impressions.]
First Impressions .
Ok now let's get down to the real deal , the Sound Quality.
Test Setup
To get down to a fair conclusion , I tried to test these IEMs with multifarious sources. The main sources and test equipments consisted of my Ipod Nano 3G,Iphone 2G, PC (XONAR DX sound card ),Fiio E5 (which was presented to me by Mp4 Nation again ).
Other than that, I also used these IEMs with meier corda Amp possessed by BF1983 for a short diration of time.(More on that later)
So to start with , after Mp4 Nation approached me for the first time for the review, I did a research on the headphones. The feedback that I got from other users got me all excited and I went ahead with the testing, pronto. The moment I got these babies, I opened up the package and plugged them into my ears. You will be surprised when I say that I couldn't really stand them even for a minute. Earphones are said to connect the listener to the music, but it actually connected me to noise that reached a crescendo. They had lots of sibilance and I felt as if my ears would bleed any moment hereafter.
I was somewhat disappointed and conveyed this to the Mp4 Nation .I was told that the earphones need a lot of burn-in and the sound changes after 100-150 hours of playback.
Did the sound really get better ? Yes it did ! The earphones don't sound their very best out of the box and need a lot of time for the sound to get smoother. For the detailed description on the sound check the next page .
[BREAK=Details on Sound Quality.]
Detail Sound Quality.
I didn't really try out the Betas during their burn in period .So the following details on Sound Quality are after the IEMs had burn-in for more than 100 hours.
For testing I played my usual collection of A.R Rahman FLACs,some Trance /Electronic FLACs, Radio shows, a few random rock, hip-hop tracks and the usual Bollywood Mp3(320kbps).
The Bass :
The Beta's are not too boomy or bellowing. It has a slight punch to it but it doesn't extend too deep. I found that the PL-30s from Sound Magic, the earphones that I used earlier, lacked in bass. This is not the case with these IEMs. Sort of perfect for my liking.(I am not a bass- head ).What's best about the bass not being too heavy is that each bass note has it's own distinct sound to it and I could make out the difference in the bassline of most EDM/Trance tracks.
With the Fiio E5's bass boost there is a noticeable improvement in the Bass but it's more of like a increase in the amplitude of the bass and nothing more .So the use of a amp for bass boost isn't really needed.
The Midrange :
This is one segment where these earphones dont really shine out . The Instrumentals sound decent and are above acceptable levels. Vocals(especially female vocals) sound very natural .The mid range is bit recessed and you can feel that there is something lacking. Overall the midrange is good enough but lacks the extra detailing and sounds bit hollow.
The Treble:
Most earphones’ sound signature is emphasized on the mids or bass but in this case it is the Treble that held me spell bounded. The Treble is very clear and detailed .The sound is slightly forward and analytical . With the filter caps on the Treble becomes smoother and more laid back. only problem is the sibilance which I was talking off earlier during the Initial Impressions. The detailing and clarity in this segment is phenomenal . The Highs are better compared to any other IEMs Ive heard under 40-50$.
Infact at times I feel the Highs are more detailed than the RE-2 as well but then RE-2 have blissful mids and the Beta's midrange cant match up to that.
Soundstage :
The soundstage produced by these earphones is pretty impressive for the price .It's on par /better than the PL-30s .The channel separation and cycling of sound is something that will impress you . Soundstage is something most cheap IEMs or infact even the expensive one's like the CX300/400 from Sennheisers lack. Another example would be the so very over rated EP-630.
What I've noticed with most Chinese and other Asian manufacturers of audio gear is that they lay emphasis on the soundstage even with the cheapest of their earphones.
Another reason for the better positioning of sound with these Betas might be the elongated shaft/ nozzle on the earphones which results in the earpiece sitting deeper and more closer to the ear, enhancing the higher frequencies.
Changes in sound with change in source :
*Ive added this section the Review so that people realize that even the source plays a important role in how your audio gear sounds.
Though the sibilance with the IEMs was reduced after the burn-in, it's still noticeable and can get on your nerves at times. The treble note get's a bit too high all of a sudden and you feel as if someone just rung a church bell in your ears.
Another important thing I noticed with the sibilance is that it is more prominent with the Ipod/Iphone ,could be because the Ipod's DAC by itself has a stronger treble . With my XONAR DX sound card on the PC the problem wasn't that big a issue.
When I used the Beta Brainwavz with Brendon(BF1983's) meier Corda amp , the sibilance was reduced by leaps and bounds and the sound was very clear and appealing . With the meier corda the IEMs sounded very smooth and they sounded the best with his amp but then not everyone can afford amps worth 5-6k.
I would rate the overall sound quality as 8/10.
[BREAK=Final Words.]
Final Words.
It took me a lot of time to make up mind on these . At first I didn't like them much but that was when they had not even burn-in. Soon it started growing over me.
Since last 1 month I've been using 2-3 different IEMs for my personal use .Initially I didn't use the Betas regularly but now I find the overall sound and detailing of the Betas much better that the other budget IEMs I have , also I have also developed a liking towards those ultra comfortable foam tips.
>>Pros:
* Attractive packaging and accessories.
* Detailed and natural Highs.
*Good soundstage
*Decent build Quality.
*foam tips are very comfortable.
>>Cons :
* A bit recessed midrange.
*Sounds a bit hollow. There's room for improvement
* Bass might be low for some.(Subjective)
*lack of support in India. (will have to ship it back to MP4 nation for warranty purpose)
[BREAK=Conclusion]
Conclusion :
To conclude, I wouldn't say that these are the best IEMs, because in this price range there are a variety of options flying under the radar. So ultimately it comes down to one's personal tastes. These are best suited for someone who prefers detailed highs with wide soundstage and and a decent midrange ,ofcourse the bass is there as well but not the kind of Bass which bass-heads crave for.
To sum it up , I would rate them as 8/10 overall and for the current discounted price of only 24.50$ (were selling for 35$ when i received them), these are well worth it if they match your listening taste cause as they say -
Music to one's ear maybe noise to others.
*UPDATE*
Just an Update. Completed almost 200 hrs of playback on these babies and they sound really awesome now.Just noticed that the sibilance is almost gone. sound has opened up little bit and the bass has increased and it's more of pumping bass now. I likes it. :D
Now I feel ,I can say that these are one of the best options around 1.5k mark. Better than the PL-30s as well :).
Anyone who get's these ,keep in mind that they really sound crap out of the box. Needs a lot of burn-in to open up and gets over you gradually.You will start liking them. ;)
*Special Thanks to Raz from Mp4 Nation for providing me with the review sample .
*Also would like to thank Sumchamp from TE for helping me with the snaps using his Panasonic LZ8.;)
Here are a few more pics of the Betas. Enjoy !
Posted Image
Posted Image
Posted Image
#2
Dark Star
Very nice review :) the earphones does look good :P
I might sell my Ep630 and get one of those ;)
BTW were you shaking while taking pics :P
#3
FaH33m
Thank You Darkstar :).The earphones are indeed good. There's a lot of competition in this price bracket and one needs to buy according to his preferred sound signature.
I know the pics could have been better but I am not used to clicking snaps using digicam and also have bit shaky hands. Sumchamp had come to my place today , so clicked these in a bit of hurry using his LZ-8 .Pretty good cam .
#4
Party Monger
The metal filter looks good:) how did it feel in the ear?
#5
Metalspree
Nice Review mate.
#6
raksrules
You sort of official reviewer for MP4 Nation ? :O
Awesome man.
So are we going to find the RE2 in market section soon ?? :P
#7
salluks
very shaky hands, try using a tripod!!
very good review tough,
#8
salluks
very good review,
try a tripod next time, very shaky pics
p.s. - do they let u keep the earphones or do u have to return them?
#9
FaH33m
The filters are very light weight and the difference isn't much with or without the filter. Just the treble gets a bit smooth.
Metalspree said:
Nice Review mate.
Thank you :)
Awesome man.
Hmm not official Reviewer exactly ,but yeah you will get to see a few more Reviews in the future. Maybe a Sound Magic PL-50 soon.;)
and yeah I am not using the RE-2 since last 2-3 months They died twice and a one was sort of DOA so Ive sent it back .Most probably will be getting a RE-0 in return.
I took the pics in a bit of hurry and I think I have this shaky pics when I click using my right hand . I am lefty and at times have problems with cameras.:ashamed: Hands need to be a bit more firm maybe.
salluks said:
very good review,
Thank you. will try and get hold of a tripod next time.
I get to keep the earphones, but I am not sure if I will be using them regularly cause the sound's not exactly like what I prefer.(need more detailed mids).
Also I will mostly be getting better stuff in the future.
#10
sumchamp
Very nice and detailed review. :)
#11
FaH33m
^ Thank you . and yeah thanks for helping me with your LZ8.
Though Ive tried to add every details in the Review , incase any one has any queries regarding the IEMs or the sound . I will be glad to answer them :).
#12
Brendon
Great review as usual Faheem ! I like that you use lots of pics and your descriptions are very elaborate. Keep it up ! :)
#13
FaH33m
Those words coming from your side , really means a lot :). Thanks .
#14
medpal
good review keep up the good work.
#15
thexfactor
Nice review Faheem ... keep them coming :)
#16
MusicisLife
Nice review..:hap2:
#17
Amarbir
Well Boy ,
Good Job Here ......Keep it Coming .
#18
Spy king
Hey, I'v been using these IEM's for couple of months now(got them in the pre-sale)
few things,
-The wire has no actual strain relief at the y joint, so be careful!
-Out of all the tips, The bi-flange ones are probably the best.. the foam ones are rubbish..:P
-The phones do really sound much much better after burn-in. They sound like a totally different set of phones after about 100hrs of burn in..!
-I never for the life of me could figure out how to use those headphone winding clips.. could someone take a pic and show me?! :)
#19
karmyster
Nice review, looking forward to more.
#20
viralbug
Nice review.
Waiting for more. :D
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
  • Facebook
