Jump to content
Background light problem
5 replies to this topic
#1
rohitshakti2
Hi,
I am using Nokia 3250. THe problem is that sometimes the background light goes off and it again comes back after some time.
Secondy my bluetooth is also not working.
Pls tell me what could be the problem and how to correct it.
Regards
#2
rohitshakti2
Kya baat hai, nobody knows how to solve this problem
#3
rahul9250133815
i know how to solv this problem first disassemble your phone and than clean its pcb bord with pcb cliner or asetone u can get it form any madical store near your house than dry it with a hair dryer then put the pcb back in your phone and the backlight problem should be solved
#4
ɱɑɖɖʏ
For Backlight Problem
Do what rahul is saying:ohyeah:
For Bluetooth Problem
Check for a firmware upgrade or do a phone format *#7370#:ohyeah:
#5
rohitshakti2
What is pcb cliner or asetone, it is something like sprit/thinner used to clean products or something else.
Regards
Rohit
#6
coolpcguy
If you don't know about PCB cleaners or acetones, just take it to your dealer and get it serviced from there
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
