Guys.. I have Windows XP n My LCD is full HD and supports 1920 x 1080 resolution as best resol.... My Mobo integrated gfx card (nvidia) also supports it... and my current resol is 1920 x 1080... I have installed d latest drivers... but the icons and everything is toooooo small and i have to focus to read d text... the display looks very sharp.... can somebody help me bout the icon and the e explorer windows?
9 replies to this topic
#1
Posted 05 September 2009 - 04:42 PM
#2
Posted 05 September 2009 - 04:53 PM
if you have tuneup utilities there is an option to increase icon size. other than that there is a setting in vista to increase icon size. but since you are an xp user try tuneup utilities.
for text size you would have to increase the size from normal to larger.
#3
Posted 05 September 2009 - 04:55 PM
try setting resolution to 1680*1050.
most of todays full hd monitors has two native resolutions >1920*1080 and 1680*1050.
screen should look equally good on both these resolution in supported monitors like Samsung 2233sw, or dell 2209s...
and do let us know if it works for the g2220. im too planning on the same. :)
#4
Posted 05 September 2009 - 05:07 PM
1920*1080 has 16:9 ratio while 1680*1050 has 16:10...
so 1680*1050 wont look as good as 1920*1080 in full HD monitors..
#5
Posted 05 September 2009 - 05:16 PM
@ dominator 1600x900 , not 1680x1050 for that lcd :P
#6
Posted 05 September 2009 - 05:23 PM
just increase dpi
you can find it in nV control panel as well as desktop properties.
#7
Posted 05 September 2009 - 06:33 PM
This is what happens when you believe in all this Full HD crap dished out by LCD manufacturers. For all practical purposes, 1680X1050 is perfectly fine for a 22" monitor. Anything above that is simply marketing crap that does more harm (16:9 and small pixel pitch, greater GPU requirements) to a 22" monitor than good. Instead of more pixels, what we should really care about is LCD panel and colour quality.
BTW, spawnfreak, increase you DPI settings. It will help assuage the situation somewhat.
#8
Posted 09 September 2009 - 07:54 AM
for the icons.
you can use TuneUp Utilities.
#9
Posted 14 September 2009 - 05:27 AM
I am using this monitor and there is an option in window 7 under screen resolution to make text and other items bigger or smaller.this option must also exist in every other windows or other os.Use it
#10
Posted 01 July 2010 - 01:30 PM
Ok im gonna post my problem in this same topic...I have windows 7, 22" Benq g2220hd monitor, gf9600gt...so my problem is that when i use 1920x1080 the screen gets out of monitor...its like i dont see the start button and i dont see clock and other icons same as lang. bar in bottom left and right...so the sides are out of reach...when i use 1680x1050 its the best resolution that i can use...so if there is any1 who can give me a hint how to fix this i would appreciate it!!
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Sign In
Create Account
Back to top
