Full of options for expansion, the case fits high performance 10.5” graphics cards, up to 4 external 5.25” drives and 5 internal 3.5” HDD racks. Beta EVO provides a number of features that significantly enhance ease of installation including screwless installation for 5.25” drives and superior wire management capabilities with the bottom mounted PSU and 180° turned HDD cage. It also features punched holes in the motherboard allowing for quick CPU bracket removal.
- Fits ATX Standard Motherboards and Power Supplies
- Fits large 10.5” performance graphic cards
- Expanded cooling directly cools video cards and CPU
- Support for up to 6 120mm fans with the option of dual 140mm at the top
- Screwless installation for hard drives and external 5.25” drives
- Black Internal finish for sleek look
- Meshed front panel allows for better airflow than traditional cases
- Superior wire management with bottom mounted :: PSU and CPU punchout for heatsink removable
- Removable PSU filter
- 180 degree Turned HDD for a cleaner internal finish and better wire management
- External Dual radiator support
- Top mounted USB/Audio for convenient usage.
Now ask the price it would be around 50$:bothways: and would be available this sept.
Added to my wishlist.....Woah i m loving this one:):)
Sign In
Create Account
Back to top
