Jump to content
Buying LCD need Help
31 replies to this topic
#1
YashBhatt
Well guys,
Since my OLD Samsung SyncMaster 793s CRT is giving me problems with displaying a tinted yellow color over the screen which is really irritating
I have finally planned to buy a new LCD
Since iam low on budget,I have selected the Samsung 2033SW
Any other good LCD within the range of 7-8k
Also wanted to know the difference between samsung 2033SW and 2233SW
Just the size difference ?
Thoughts ...
#2
Spectre
whats your main requirement
For Gaming
Dell E1909W
For Movies
samsung 2033, since your gfx card cant keep handling games for much longer at 1920 native resolution
#3
YashBhatt
Now wht does that mean ? :huh:
Saphire HD4850 DS can't handle/ support games at 1920 native resoln. :wtf:
#4
saqib_khan
Naah.. 4850 can handle Full HD. Its just that in some games like Crysis, u have to play in lower settings, otherwise 4850 is fine.
#5
Spectre
What i meant is, as the resolution keeps going up, the framerate is gonna come down
so, your 4850 though is a good card cant keep up with good framerates with all the AA and AF, high textures etc at this resolution for much longer
games like GTA4 and Crysis will lag at 1920 but will play smoothly at 1440 with your card, unless many of the visual settings are toned down
Else why would people invest their arm is getting the best gfx cards out there
#6
YashBhatt
hmmm,i won't be gaming at 1920 resoln.
Around 1440 :)
btw,whts the difference between 2033SW and 2233SW ?
Just 2 inches more ?
#7
Spectre
Around 1440 :)
then all the more reason to get E1909W
bcoz monitors look their best at native resolution
and reducing resolution to such extent is only going to degraded the visuals
on the other question, am not sure, perhaps others can help
#8
saqib_khan
Samsung 2033 >> Resolution: 1600 x 900
Power Consumption: 37 Watts
Samsung 2233 >> Resolution: 1920 x 1080
Power Consumption: 40 Watts
All other technical specs are same and u already know the screen size of both.
#9
YashBhatt
I also have a AOC 2036SA in mind
Looks promising
But how is the after sales service provided by AOC
Link to Monitor - http://www.lynx-indi...categoryID=3280
Within my Budget
#10
mithunfan
i hav similar concerns...but my biggest concerns is wich monitor wil let me see 700 mb rips with a decent visual experience (less degradation)
2033/2233/1909?
#11
saqib_khan
^^ For that thing, go for 2033. And previously also, u told that u don't wanna game in 1920 res. So I think u should go for 2033 :)
#12
sato1986
Would recommend not to waver away from the current choice:
Samsung 2033SW (1600x900) : Excellent for Movies, Superb otherwise
Dell E1909W (1440x900) : Excellent for Gaming, Superb otherwise
Both are excellent monitors which superb color reproduction, 5ms response time (typical).
Both have the Best A.S.S. in the country and come with a 3-year warranty.
#13
YashBhatt
So should i go for a Samsung 2033SW at Rs 7,350/-
NO to AOC 2036SA ? Its costing me Rs 6,800/- here in mumbai
#14
mithunfan
ud rather go for a samsung than an AOC....
#15
YashBhatt
Hmmm,wht about the Dynamic Contrast Ration between the 2 monitors
Samsung 2033SW has a DCR of 15,000:1
While AOC has a DCR of 60,000:1
Does that affect your viewing ?
#16
mithunfan
afaik...a superior DCR shows effects wen viewing scenes that contain a high percentage of black..scenes that go over sum time. tht too wen ur room is not lit.
this might be a test case type of a situation. hence a DCR figure shouldnt really be influencing ur decision in my opinion.
anyone...plz correct me if im wrong.
#17
mithun
Being an AOC user for over an yr now i can say that AOC ASS is top class, but the IQ is not as good as Samsung panels. Stick to the 2033sw.
#18
foruamit2004
@OP
you can check samsung 2043, 20" with 50000:1 DCR, probably 100-200 buck more then 2033.
#19
YashBhatt
foruamit2004 said:
@OP
Samsung 2043SWX has the DCR Ratio - 15,000:1
Source - 51cm (20) widescreen LCD monitor 2043SWX - Desktop Monitor - Monitor | SAMSUNG
Whereas,Samsung 2033SWPLUS has DCR ratio - 50,000:1
Source - http://www.samsung.c...=LS20CMZKFNALXL
#20
Superbad
Samsung 2033 sw plus is @7200 at lammy.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
