Jump to content
gaming problem CRT & LCD
4 replies to this topic
#1
saman
helloz
i play counter strike on my home PC,on a CRT
Samsung Syncmaster 793s at 640x480
it can support 120hz refresh rate, and im very used to it
i was wondering if u go on a Gaming Caffe,they have LCD
so LCD dont support more than 75hz refresh rate
so it will make any difference because i have heard that in LCDs refresh rate dont matter only response time ( ms thing ) matters
#2
dOm1naTOr
yup
LCDs @ 60Hz wont feel like blinking as in a CRT.
But LCDs has a problem of trailing and it is reduced by faster response time.
Most of todays LCDs has 5ms or lower response time, so the trailing caused cant be found by human eye in most situations.
U can go for an LCD eyes closed. But caffe might be having old models, with 8, 10 or even 15ms which can cause trailings.
#3
saman
You mean,if u play on 120hz on a CRT & on a 2ms LCD
it is same thing ?
#4
sato1986
For Counter Strike , Just dont worry: u will find easier to play on LCD than on CRT :)
Just remember to keep Vertical Sync OFF :)
Anyways, LCD is much better than CRT in terms of Eye strain, Detail, Sharpness..
#5
saman
Im very thankfull to you
Rep given ! :)
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
