Jump to content
Help need for buying 19 or 20 inch LCD.
8 replies to this topic
#1
DevilMind
I got option of buying LCD:
Dell E1909W -19 inch
HP 2009f Wide Screen -20 inch
Samsung 2033BW or 2033SW -20 inch
(plz tell me difference between these BW & SW series by samsung)
I will use them for Playing HD movies...Playing PC Games...& playing Xbox 360 Games on this LCD...
which LCD should i buy???
#2
Crossx
Dell E1909W is hard to find. If you can get one, dont look elsewhere, its a great 19' monitor. If you need bigger monitor, then look for 22' monitors from Benq or Samsung.
#3
saqib_khan
In that 2033SW is the best. Its strange I can't find 2033bw model in Samsung's official site. Specs differ between them. 2033SW has 1600 x 900 and 15000:1 contrast ratio whereas 2033BW has 1680 x 1050 and 20000:1 contrast ratio. R u sure abt availability of 2033bw in India? But then also I think u should go for 2033SW only.
#4
bigbyte
where do you live. what quotes you got for these lcd's.
#5
d@rK nEmEsIs
Get the Samsung 2033SW,
the difference between bw and sw is in aspect ratio afaik.
#6
ɱɑɖɖʏ
Go for Samsung 2033SW:)
Difference is the aspect ratio:ohyeah:
#7
bigbyte
Quote
Not only that... The differnce lies in well guarded dotpitch specs of Samsung 2033sw. here you go
Dell E1909W
Resolution:1440*900 16:10
Dot pitch: 0.285mm
Screen Size 410.4mm *256.5 mm
Samsung 2033sw
Resolution: 1600*900 16:9
Dotpitch: 0.2768mm
Screen Size: 442.8mm X 249.075mm
Hence due to non standard resolution and non standard dot pitch the height of Samsung monitor is actually little less then Dell E1909W. Take your pick.
#8
ragzdiablo
i bot hp 2009 20'' monitor a week back..and it is the most stunning luk wise....m quite happy..
#9
prandi
i called dell,,1month back just to find wat models are available,,theysaid Dell India only has E1909,,i u want nething else u will have to wait!!!dont know wats the scene now,,take dell,,i have seen them in dell showroom ,,they r awesome:hap2:,,their service is also good!!!
