guys can anyone help me with the problem
the default temprature of this gfx card is 70C and when running some high load stuff it reaches to 90C easily wht should i do???
Heating problem in Xpert Vision Nvidia 8600gt 512Mb
Started by siddhantmahajan, Jun 22 2009 03:25 PM
6 replies to this topic
#1
Posted 22 June 2009 - 03:25 PM
#2
Posted 22 June 2009 - 03:32 PM
Complete configuration including the psu please! Make it a habit next time when you asking for hardware advice :). Or else its better to use your config in your siggy.
#3
Posted 22 June 2009 - 03:58 PM
Intel Dual Core E5200 @ 3.25 GHz | Kingston 1GB*2 RAM 667 MHz | Palit 8600GT 512MB GFX | GigaByte G31 ES2L | Creative T6060 5.1 Speakers | iBall Piano 27 Cabinet | iBall SMPS 450W | Western Digital WD6400AACS 640GB |
#4
Posted 23 June 2009 - 06:24 AM
bump................................
#5
Posted 28 June 2009 - 05:35 AM
#6
Posted 28 June 2009 - 06:05 AM
Intake/exhaust fans for the enclosure? Insufficient ventilation can lead to high temps. inside the enclosure.
The thermal goop sandwiched between the GPU and the heatsink could've dried up as well. Remove the heatsink from the card, apply a rice-grain worth quantity of a good TIM (short for Thermal Interface Material) and screw the heatsink back to the card.
Clean the heatsink-fan as well. Dust might've clogged in!
#7
Posted 28 June 2009 - 08:21 AM
@gannu thanx a lot dude will try it out
hope it works
hope it works
Sign In
Create Account
Back to top
