Jump to content
Need help with my 5800
16 replies to this topic
#1
ajex
It happned while i was listening music through the nokia default music player ... the player suddenly crashed and the phone became unresponsive ..i waited a few minutes and then killed the music player app using handy taskman .... eversince the music player app is not working :( .. when i click its shortcut the screen gives a little flicker and nothing happens ... i did the cold reset with *#7780# ... no help ..then i did the hard reset with *#7370# and still no luck ... the only way i can listen to music now is with the ringtone selection scroll :( ... should i update my firmware ... will that help? .. iam on the default v11 blue firmware right now ... any help will be great :)
Regards,
Ajex
#2
PhOeNiX
Take it to the Nokia Care centre. better you get the phone upgraded there. Would not recommend you try anything lest they say you messed it up.
#3
mathew_p_a
Just take it to NC and tell them the issue. Also ask them to upgrade to v20.. But it is very likely that they will do the upgrade to see whether it will fix it..
As a side note, it seems that the 5800 is a very unstable platform now and if we install thirdparty ones , they will cause trouble with the phone.
#4
PhOeNiX
Lol. Why the generalization ? No problem faced yet. Have installed roughly7-10 apps. No issues.
#5
ajex
yeah .. no issues with rest of the apps ... any last thing if want me to try before going to NCC .. coz rest is working fine .. just this music player is not loading
#6
GenetiCDisasteR
try loading it without the memcard once. maybe some of the songs are creating problems for it.
#7
ajex
^^ OMG ... YEss!!! ... it works after removing the mem card :D ... thanksssssss :) ... repped!! .. now it seems that i'll have to delete a few songs .. thanks again everyone
#8
GenetiCDisasteR
haha i'm glad that worked. it sorta happened to me too, so i had to delete all songs and worked again. i ofcourse, lost all the preloaded songs in the process... but its a small price to pay.
and dude, update your phone to v20! its far better than the old version!
#9
ajex
yeah i was actually searching through the forum for that .. i recall that someone posted a mini guide for the upgrade ... if u have it bookmarked then it'll be really great if u can post the link here :)
#10
GenetiCDisasteR
hmmm i dunno about any of those guides. but its a very very simple process.
first, backup all your device memory stuff, go to file manager>backup>options>backupNOW.
then connect via usb, use the NokiaSoftwareUpdater application (must be in the cd) to update. it will take a while to download the update, but it should be done. then you can restore your files and stuff in the file manager RESTORE option.
#11
mathew_p_a
I am sorry if I have offended any Nokia 5800 Fans:ohyeah:
As far as now, I had a bad experience with my 5800.... but it seems that all others are having a good time... I hope that the wind will turn in my favor.
I did install some apps and still have it in my phone.
Marble Maze - this is my favorite.. good response nd good one to show off the phone to others.
Touchcard match
Fring
Google maps
PDFlite- good but only trial available
It seems that the Fring application is making some trouble, by using up all memory. Also most of my programs are not going to the background mode(they are getting killed). Anyone facing the same...?
Is the response of the phone good enough for everyone? It seems that my friend's COWON is having better response than 5800. Any way to improve?
I am a whining child... Please take these quotes in a lite manner:peace:
#12
GenetiCDisasteR
mathew i suggest you try out Nokia Photo Browser, its a betalab application, i'm not sure if you heard of it, but its totally awesome. PERFECT to show off your 5800! ;)
Nokia Photo Browser for Nokia N97 and 5800 XpressMusic hit Beta Labs | Nokia Conversations
#13
G@d of w@r
if i install like 10 apps, no probs..
if i install 20 like apps, i get either home screen shortcuts vanishing or the top tabs (example: in sms, the tabs of inbox, outbox, draft doesnt shift whenever i click) gets disabled...
Yes its highly unstable phone if u install 20+ apps :@waiting for new stable firmware or i wish this platform supports windows mobile and hacks to run WM on it :ashamed:
#14
indy1811
40+ apps and games....no problems here....
#15
PhOeNiX
Quote
Quote
Yes its highly unstable phone if u install 20+ apps waiting for new stable firmware or i wish this platform supports windows mobile and hacks to run WM on it
Lol. Well it's bound to be unstable and have a few bugs. it's a 3 month old system. So give it time. But the speed at whiche the stability and the performance is increasing is great. I love my 5800 every inch :)
#16
G@d of w@r
Thats great for you guys but i had that problem twice so im scared installing all the softwares again :S.. those problems happen suddenly..
#17
mathew_p_a
Appreciate your loyalty dude. :D
