Jump to content
USB port issue after reinstalling XP with SP3
14 replies to this topic
#1
kirtibas
hi.. i am kirtibas
new here from kolkata..
its gr8 forum i found ...
I have problem from last few days.. after sever virus attack i format my pc 4-5 times now installed xp sp3.
facing lot of problem.
mother board : asrock 775dual 915GL
processor :intel P4 2.66GHz
non of my USB port working in every few seconds it prompt one of the USB device attached to the computer not has malfunctioned and window does not recognized it.
when i insert any of my unlocking box/ sd card reader or any external usb hard drive my ps2 mouse stop working
please help me.. suggest me
my every work stopped due to this problem
thanks
kirtibas
#2
Crazy_Eddy
Hi and welcome to TE.
Post your query in one of the relevant sections (in this case, I think Operating Systems would be appropriate) and folks should be able to help you.
BTW have your issues started with SP3 ?
#3
kirtibas
ur moderator.. u can move this threat to appropriate section:)
yes after i install sp3
may b its motherboard problem or may b driver problem
need suggestion
br
kirtibas
#4
Crazy_Eddy
Roll back to SP2 and see if it solves things.
There are no separate drivers to install for USB ports; they're an integral part of XP since SP2 so it could be an issue with the OS.
#5
HellBoyX2
I believe still virus affected in your PC.
install kaspersky, there is a USB Autorun virus, which does that kind of issue. kaspersky good in detecting this virus.
format your Flash disk also..
#6
kirtibas
any device not working card / external hdd/reader / memory card unlocker / jaf or ufs-hwk (mobile flashing device)
i already formatted many times.. i'll measure usb o/p volt.. i think there is not enough voltage on the usb port
i already install all sw available for mother board but facing same problem.. my mouse not work when i attack anything in usb port
thanks guys i need help
br
kirtibas
#7
Crazy_Eddy
Since you yourself admitted that these problems started after SP3, its common sense to roll back to SP2.
#8
bottle
1. try and get the latest chipset drivers from the intel website and give it a shot.
also heres something i found via google, see if it is of any help
USB Device Malfunctioned Error | USB device stops working
2. a full proper virus scan to make sure there is nothing still remaining anywhere
#9
kirtibas
already install all driver software for my mother board : asrock 775dual 915GL
from HERE
thanks ill try and post results
no virus in C:\ confirmed
my usb output volt is 1.61V its less or more than actual?
THANKS U GUYS
kirtibas
#10
bottle
from HERE
try uninstalling the INF driver that you got from asrock and install this from the intel website, seems like a newer version
 INF Update Utility - Primarily for Intel® 4, 3, 900 Series Chipsets
scroll down and click 915 series
#11
6pack
is the mouse a laser mouse? have you installed the hid interface drivers for it?
check in device manager under usb devices options if it is installed or not.
HID device shows up seperately under computer name too i think.
#12
kirtibas
all tips and trick failed same problem :huh:
its ps2 iball mouse..
stop working when i put some this in usb port
i disable usb
#13
kirtibas
i tried every thing changed smps . install new usb pci slot..but the problem remained same..
now i decided to switch on to new motherboard as well as good cpu..
dont know AMD supports all the mobile flashing and unlocking device or not(since im in gsm service professional)
im nt good as u guys in desktop pcs
plz suggest me good mobo & CPU
thanks & regards
kirtibas
#14
6pack
looks like driver issue to me. seems like some irq is clashing on your mobo.
tried enabling the device in the screenshot you gave? what does it say?
PS: give some bigger screenshots. post it on imgx.org and paste bbcode links here. attachments are quite small by default i think. almost no text is visible in the image you posted. post screengrabs of all the tabs of that dialog box.
#15
Crazy_Eddy
Pleeeease give XP with SP2 a try :)
