Jump to content
ASUS Xonar U1 USB Audio Station Review
13 replies to this topic
#1
neur0tic
Got my hands on this little UFO about 4 weeks back when I got sick and fed up of sound output of my laptop. Looking around the internet, I found this strange little thing called the ‘Xonar’ USB Audio Station and it looked like a UFO plus it said Dolby® Digital on the specifications. Frankly speaking, I was pretty hyped up about the ‘Chandrayaan’ project and having my very own UFO spewing out Dolby music on the go for a moderate budget of 4k seemed a pretty exciting proposition!
So far, this isn’t sounding much of a review and more of a rant, but here goes, anyways …
Posted Image
[BREAK=Specifications]
Posted Image
Formal Specifications:
Audio Performance:
Output Signal-to-Noise Ratio (A-Weighted):100 dB
Output THD+N at 1 kHz (A-Weighted): 0.0045% (87dB)
Dynamic Range: 96dB
Main Chipset:
Audio Processor: UA100
Sample Rate and Resolution
Analog Playback Sample Rate and Resolution: 48 KHz
I/O Ports
Bus Compatibility: USB
Analog Output Jack & Digital S/PDIF Output Combo: Analog 2CH/Digital 5.1
Analog Input Jack: Yes, stereo recording
Driver Features:
Dolby® Technologies
Dolby® Headphone
Dolby® Virtual Speaker
Dolby® Pro-Logic IIx
Dolby® Digital Live
DirectSound3D Game Extensions 1.0/DirectX
DS3D GX 1.0 supports EAX gaming sound effects and DirectSound 3D hardware enhanced functions on Windows Vista. (DirectX/DirectSound 3D compatible)
Smart Volume Normalizer™
Normalizes the volume of all audio sources into a constant level and also enhances your 3D sound listening range and advantages in gaming
Magic Voice™
Modifies the sound of your voice, for VOIP and online chat applications
Karaoke Functions
Music Key-Shifting and Microphone Echo effects
Xear 3DTM Virtual Speaker Shifter
Virtual 7.1 speaker positioning
Array Microphone
Reducing environmental background sounds and noises; keeping your front side voice input as clean as possible
Other Effects
10-band Equalier/27 Environment Effects
Bundled Accessories:
A pretty decent bundle in a small box
1 x User manual
1 x Driver CD
1 x SPDIF Optical cable and
1 x Array Mic
(Apart from the 1 x USB Audio Station itself)
Posted Image
[BREAK=Installation And Performance]
Installation & Performance:
The audio station comes with a driver CD, but it’s not essential to install the drivers for some quick music output.
Windows XP detected the device as “USB Advanced Audio Device” as soon as it was plugged in, and was ready to use within seconds. Without installing the driver of course there were no fancy Dolby effects and processing, but I still had the mixer and software volume control.
Hardware volume control which is achieved by rotating the upper semi-cone of the device was also not available without the driver.
Installing the driver though was quick and easy, and let me tell you, the device becomes a real rock-house with them. I was pleased to find all the various DSP modes pretty much handily placed, so I don’t have to keep modifying the equalizer all the time.
The presets included movie, music , game and hi-fi. The manual customization options are plentiful with the entire set of Dolby technologies, including virtual speaker, pro logic etc. But what really made me jump was the Dolby Headphone option. I just could not believe that I was hearing music on my same old headphones.
Posted Image
The sound is very clear and the powerful amplifier really makes any headphones thump. The bass output was remarkably good, and I was surprised to find that, because on such small devices it is generally otherwise. Not to mention overtones did not distort and hi-freq cymbals sounded almost true to life.
The only time I found some clicks and pops in the audio , were during the dxdiag audio test. There would be a small click, every time the next sample was up for playing. It might also be that these sounds have just become more prominent due to the heavy pre amplification. The advantage is that anyone who is on the move or travels through noisy traffic or a noisy environment will surely applaud the U1’s audio output level.
The U1 has 2 jacks in the front , for the headphones and the mic. The headphone jack also doubles up as an SPDIF connector with the SPDIF attachment provided in the bundle. Sadly, I cannot comment on the SPDIF capabilities because I don’t have that exotic a setup to test it !
Posted Image
Also, as I was talking about hardware and software volume control, the U1’s upper half can be rotated clock-wise and anti-clock wise to control the output volume and depressing the same, functions as mute and un-mute. I’d say kudos to ASUS for simplicity and great ergonomics. The volume control does give you visual feedback too.
Coming to the mic included in the bundle, supposedly, it is an array mic. The mic works very nicely with skype and has good gain.
Posted Image
Whats an array mic?
An array microphone does for microphones what your brain does for your ears. It gives them some intelligence. The general idea is that you take a set of microphones—which could be two, or eight, or thousands—and add a DSP chip with some sophisticated logic. The array microphone’s processor continuously figures out where the primary speaker is in the field of audio input it’s receiving, and selectively adjusts the output so that most of it is coming from the microphone that is getting the best signal. This amounts to “focusing” on a certain direction and distance so that the speaker’s voice, and little or no other noise, actually reaches the output.
Courtesy: Array Microphones: Interesting Thing of the Day
[BREAK=Concluding Remarks]
Concluding Remarks:
The ASUS U1 USB audio station, is a very well designed and well performing equipment, fills up my requirement for being highly portable bundled with a great sound output level and good audio quality.
So , you get style, portability , ergonomics and thumping music for about Rs.4000/- do I need say more ?
Hope you all like my first review on TE !:cool2:
#2
titana
where do u get it for 4k ?
nice review, by the way.
#3
karan2670
Yep, I would like to buy it too.
Where do you get it from in Mumbai?Any ideas ?
#4
ultimabasher
Nice nice. Repped :)
#5
Buygamingstuff
Suro bhai Nice review n welcome to TE mate
Good work :)
Repped !! :ohyeah:
#6
neur0tic
I got the thing for 4500 from vijay (see post above)
BuyGamingStuff.com
#7
Lord Dagon
Nice review.
#8
TheNightwing
That UFO is certainly on my must have list.
#9
SRI 420
Brought one today, tested the sound output with my Desktop PC with the following configuration: DG35EC M Board. E 7400 Core 2 duo processor 2 GB of Ram running Vista 32 bit. The quality of the sound it gives out is awesome, found tremendous increase in sound quality. will test recording/mixing some karaoke tracks tomorrow. Actually that was my primary purpose of getting this as this has a built in karaoke feature with Mic echo.
#10
kritarth
what is the price for this now ?
#11
harryneopotter
3.5-3.6 k shipped !
#12
Happy Singh
Nice Review...good going ASUS
#13
ViKiD
I bought one recently from SMCinternational ..... awesome for portable uses as well as for powering Mid end Hp's :)
Overall SQ AWESOME!
#14
SRI 420
I got it for 3.4K at Hyderabad. It could have coasted me still less but the distributor said that he cannot sell to me (i.e. a customer) directly and hence had it sent it to his dealer, whose margin of Rs. 200/- got added.
Srinivas.
The distributor's price was 3084/- + taxes.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
