Hello Frenz,
I am facing a wired problem since i bought Corsair voyager 16GB pendrive:S .
There is a USB slot on my DVD player but it is not supporting Voyager pendrive as Sandisk 8GB cruzer micro skin runs perfectly without any issues. I thought pendrive must be faulty, So i use it on my another DVD player i.e. Philips and it runs smoothly. What can be the problem and how to solve it. I think the issue is with the speed of pendrive or any other guess.
Hope my frenz will find an effective solution for this problem.
Advance thanks:clap:
5 replies to this topic
#1
Posted 16 December 2008 - 03:00 PM
#2
Posted 16 December 2008 - 03:10 PM
There is no question of speed issue. Either of two below:-
1. Check file system on USB drive, if NTFS, it may be one of the reason as all players are not compatible with NTFS file system and can read only FAT32
2. Your player may be supporting upto 8 GB only.
#3
Posted 16 December 2008 - 04:17 PM
Hi Stud,
I have consider your views, please read below
1) When i use Sandisk 8GB Cruzer micro skin, it works absolutly fine. Before corsair 16GB voyager, i used to have 8GB Kingston datatraveller which works fine in early times (I mean 2-3 mnths back) but after few months it was also not readable like 16GB voyager by my DVD player.
2)Mine earlier kingston was also 8GB but that one also fails in working after 2 mnths on my dvd player.
My DVD player is reading pendrive as you can see SANDISK 8GB but why it stops reading 8GB kingston and never reads 16GB corsair voyager.
#4
Posted 16 December 2008 - 06:36 PM
i fail to understand why uve started multiple threads for the same issue. please refer to the other thread.
mods, please merge the threads.
http://www.techencla...eed-124407.html
#5
Posted 16 December 2008 - 06:40 PM
Buddy i agree with you but this thread is regarding SAMSUNG HT-Q20 (Its a consumer product) and i want to troubleshoot it. I hope my answer is genuine.;)
#6
Posted 16 December 2008 - 06:45 PM
yes and ur other one was regarding the pen drive in the storage section. but the main problem is the same and it is pretty obvious that you have created multiple threads for the same issue. anyhow, have a look at what i posted in the storage section.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Sign In
Create Account
Back to top
