Jump to content
What to expect ? or What to add to Speed Up?
8 replies to this topic
#1
idlehearts
Hello friends
i am thinking of selling my PC OR Upgrading it
What do i add if it is possible to upgrade
AMD Athlon™ 64 Processor 3000+ 2004 Mhz
MB: ASUS K8S-MX
Ram 2 X 512MB 400 MHz
1 Sony DVD RW
1 Sony CD RW
1 80GB Hard Disk
14" CRT monitor
Posted Image
PLEASE SUGGEST ME
#2
Naga
Purpose and budget? If gaming's on your mind, u need to get a whole new setup. For office/ normal use, maybe a monitor upgrade?
#3
Techman
Looks like the branded pc from asus ... you can sell as a whole pack for a decent price and go for a upgrade.
#4
forum67
keep the 80GB has a external Backup HDD with a HDD casing.
#5
idlehearts
Quote
Purpose: Will mainly use it for browsing and designing websites and once in a week convert movies (from Non -AVI to AVI, DVD to AVI)
Budget: till 30K for new one / 5-8K for Upgrade
Will not use it for any games
May open many applications like Photoshop, dreamwever, Dual OS( using Virtual PC)
Quote
No its not a Branded One it is a assembled one
Quote
I am currently using 80GB disk which is 90% full
AND
Can i update it with latest avaliable RAM that is more than 400MHz speed
Now a Days my PC is getting stuck every now n then with XP and Vista
Thanks
#6
Naga
If budget is 30k, get a new machine instead of an upgrade as ur machine is good as it is.
http://www.techencla...8-a-116085.html
#7
tangentray
+1 to getting a new machine -- for the proposed use you will get overkill in 30K.
#8
saintsinner
MrRIG said:
Add power Supply Rs. 550 2yer warranty Iball.
Are you serious about the Iball PSU??
#9
H2O
Get yourself
AMD X2 4400+ Rs. 2500
Biostar 780G Rs.4000
Transcend 2x1GB DDR2 800 Rs. 2000
Zebronics Bijli +PSU Rs. 1500
