Here is my config
CPU: AMD Sempron Processor 2500+
Motherboard: Asus K8S-MX
Memory: Hynix DDR400Mhz 512MB
Here are some similar problems I had previously
http://www.techencla...ezes-72540.html
http://www.techencla...gain-70636.html
The second link describes the present problem closely.
Here is the present status
The PC was booting fine yesterday on onboard.
Today I bought Bijli and a zebronics 450W PSU and transferred the setup. It didnt POST.
The mobo led glows, the CPU fan spins, the dvd drive gets power but there is no display on screen.
I tried 3 different PSUs in all. I also tried a gfx card GF2MX, the fan on the card spins but no display.
Pulled out everything and connected just the PSU, mobo, RAM and monitor. Still no display. Tried 3 different RAM sticks in both slots.
Also tried resetting by pulling out the battery for an hour. Moving the reset jumper for half an hour. Neither of the method worked.
There is no system beep either.
I searched around the internet and found hundreds of links with same problem with no specific solution floating around.
And yes, pressing the power button for even 10 seconds just doesnt shutdown the mobo.
Last time I had this problem it started working fine later.
23 replies to this topic
#1
Posted 28 May 2008 - 07:26 PM
#2
Posted 28 May 2008 - 07:32 PM
try cleaning the ram slots with a paintbrush n try again
#3
Posted 28 May 2008 - 07:37 PM
just this kinda problem i once faced with my previous system Asus P4533c mobo + P4 2.4 ...so then finding no way out i personally went asus service centre... they took sum 2 hrs time n give me back my mobo saying alright but within 2 weeks its back to that similar condition again... i just changed the power cord of monitor and cabinet and all goes fine... i know this sounds pretty funny but it happand with me earlier.. u may check this also as u already troublshooting al possible way around
#4
Posted 28 May 2008 - 07:38 PM
Renegade said:
Here is my config
Uh Renegade, seems the motherboard is nearing its EOL; :(
It should be at least 1-1.5 yrs old.. :huh:
If it has warranty, even then ur problem is double thronged - RASHI!!! :ashamed:
Seems u've tried all possible knacks which otherwise I'd have suggested now; :(
#5
try a different processor?...
#6
Posted 28 May 2008 - 07:48 PM
@renegade i used same mobo with 2800+ athlon....face same situation after 2yrs usage.....the cpu fan worked...even my 5200 powered on...n led glowd on mbo too....yet no display....tried everything...wtever u did....finally gave it to my dealer....he sent it to asus....got it back but said mobo gone kaput wen they tested for a day.....then said as it went kaput due to them...they fixd it up for me....then no probs....until i gave em back as buyback..:P
so according to me time to get new mbo or try givin it to local repairer..may fix it..
#7
Posted 28 May 2008 - 07:54 PM
remove everything out of the box........set it up on a table......and check if it works....:) ......or jus check for any shorts anywhere.......
#8
Posted 28 May 2008 - 07:56 PM
@sunny - I cleaned the slots with a narrow nozzled blower and then with a brush.
@game - will give it a try in few minutes, have 3 such cables lying around. Though the monitor is fine since I am using it with my laptop right now with extended desktop dual monitor. :P
@gannu - It is 3 years old so no warranty.
@kippu - where will I get a sucky ages old processor. That can only happen when I get official paid help. So 2nd last option.
last option of course is to buy a C2D. I even bought 1GB DDR400 RAM today :(
EDIT - @hanzy - thats what I have done right now. Its all laid out. Cant seem to locate any shorts or blown capacitors either
#9
Posted 28 May 2008 - 08:01 PM
Dammit.. :(
Anyhow u'll get a good Dual core CPU + Mobo + RAM for 6.6k; :)
So no issues;
Sell that RAM back to the dealer; :)
#10
Posted 28 May 2008 - 08:15 PM
Remove both the RAM's......attach the system speaker to the mobo.....and see if it beeps....if it doesn't beep....then its either the board or the processor........to be sure abt this......remove the processor...blow clean area where the processor sits.........reset it.....and don't clip on the HS completely...jus run it loose and check......if the board beeps....something wrong with the ram slot / rams....
#11
Posted 28 May 2008 - 09:09 PM
Am just too tired to try that right now. Will do it tomorrow afternoon. Thanks for the input guys, will update tomo. :)
#12
Posted 29 May 2008 - 02:21 AM
Its morning !!!.....get up :P do the stuff......all the best for the trial , i know and exactly understand how irritating it can be....just try the stuff without the rams as i mentioned and we could narrow down on the issue.....sorry won't be able to check TE until evening......:cry: ...
#13
Posted 29 May 2008 - 02:36 AM
a zebby PSU claims its next victim :(
same thing happend to my A7N8X when i plugged it into a zebby 500W. was booting on Old PSU. died when i plugged it into the zebby.
My advice , RMA the mobo, get another PSU. The zebby psu will work, but its a killer :no:
#14
Posted 29 May 2008 - 07:20 AM
i think its the psu that maybe causing a problem.. did u check it with another one ?
#15
Posted 29 May 2008 - 07:26 AM
the PSU is in all probably the one which caused the problem. But the mobo should be dead by now :( . I think the mobo is from the capacitor plague era, so particularly susceptible to damage.Newer ( recently manufactured) mobos might have a better chance of surviving the PSU
#16
Posted 29 May 2008 - 07:50 AM
Yup it seems the motherboard is dead :cry:
#17
Posted 29 May 2008 - 09:58 AM
Alright.. no RAM no beep
No HSF no beep, the proc does get heated though without HS.
Even tried setting all jumpers to default as shown in the manual.
Also tried a hard reset (no battery + CMOS reset jumper) overnight. No show.
Might just throw it in bin by tomorrow.
As for the zebby PSU. There is no way that I am going for a 1.5K+ PSU so I doubt any other PSUs would be any better. Is there any particular issue with the zebby PSUs.
#18
Posted 29 May 2008 - 10:09 AM
Quote
#19
Posted 29 May 2008 - 10:33 AM
So that concludes u're getting a new rig Renu??? :)
#20
Posted 29 May 2008 - 10:36 AM
:P maybe yes. All of a sudden I get one long and two short beeps without RAM
Sign In
Create Account
Back to top
