ultimabasher said:
U ARE WRONG BRO
it is limited by SATA 1
if he switches to sata 2 then he wont get 300 mbps
it theoretical
u get arnd 250 mbps to be precise
first it is not sata1/2
it is sata-1.5Gbps and sata-3.0Gbps.
my frnd , sata1/2 is all FUD
see here
http://www.techencla...oid-108926.html
seagate 7200.11 has got max speeds of bout 100-105 MBps.
sata 1(if that's what u like to call it) supports upto 150MBps , still above theoretical speed of 7200.11.
then plz explain me how is it limited by sata1????:S
until the speeds go above 150MBps , nobody is limited by sata2/1.
that guy does not need any mobo upgrade for this hd.
again only thing he is missing is ncq(needs ahci mode not ide mode)
thus he is practically missing nothing.
to make it easier , dvd drives still have got very slow data rates. thus they get practically no advantage from sata interface. even today , burn times/read times of dvd drives are same no matter what u choose sata/pata.
but by ur analogy if drive manufacturers started to give sata2 interface than sata 1 , that would increase drive performance to double.
and now the jumper thing.
sata2 mobos support auto negotiation. thus if u plug in any sata drive it will detect its speed and run it on its supported sata revision.
but sata 1 mobos do not support it.
thus sata 2 disk will be unsupported by sata1 mobo . that jumper is provided to hard-fix the drive to sata 1 , so that it is supported by sata1 mobos.
to every new tech there is a fine print my frnd.
