kartikoli
i need a window ac for my hot room which is around 200sqft and have direct sunlight on one side of a wall and sealing. Currently i was using voltas vertis 2Ton window ac and i never had any issue but now i have sold it as it started giving problem after 6yrs of use
Now i believe any good ac of 1.5Ton is sufficient for this room so looking for suggestion
What i want
- good cooling
- good ASS
- good build quality
- dont need star rated ac as my other ac does the job and i am ok with any star
I can shell out 30~35k and even more if the product is worth (we dont buy ac every yr.). I am currently looking at hitachi , general ac's but can go for other company if it packs a punch
SECONDLY need a suitable stabilizer for this AC ~5k budget (separate)
What i want
- good cooling
- good ASS
