WiFi Router + USB modem
Hi All,
Just recently purchased MTS Blaze, now I"m looking for a router which will take the USB modem as input and provide Internet
Thanks for any inputs you may have
P.S.
The MTS Blaze is a EVDO/CDMA device
Thank you all very much for your suggestions, I'm thinking of going with Tenda, seems like a good one, regarding the ASUS RT-N13U, that's a nice router, but I have EVDO not 3G so skeptical about it, if anyone has any confirmations then that would be my first option
delhiboy1000 said:
have you confirmed that the Tenda supports USB EVDO modems? at 4.5k , its a good 2k costlier than the asus..!
http://www.ekwireless.in/modems.html
It supports the following modems
Tenda
Reliance Netconnect +: Huawei EC168C, Huawei EC1260, Huawei EC1262, ZTE AC8710, ZTE 2726
Tata Photon +: Huawei EC168C, Huawei EC1260, Huawei EC1261, ZTE AC 8710
MTS: ZTE AC 2766, AnyData ADU-555C
BSNL EVDO: ZTE AC 8700
BSNL 3G: Huawei E156G
MTNL 3G: Huawei E156G
You can also check the EDIMAX router, has 3 years warranty. Which is your modem model?
Apologies for the late bump.
I also want to set up Wi-Fi using the RJ45+USB Modem combination. I looked at the above threads and not really sure which model to take. Do all have the RJ45 input capability. I have the EpiValley SEC-8089 which this model shows compatibility with. Is this a decent buy for what all I want..?
What else are good suggestions, also looked at EK Wireless compatibility list here, and their Hame, Dovado, and Cradlepoint series support the SEC-8089.
Any other suggestions/insights would be great..want this set up early as possible....!
1. BIGPOND 3G9WB ROUTER - it comes with a sim slot you directly insert the sim and use the router, no need to buy a usb modem for the same.
eBay India: Bigpond 3G9WB 7.2Mbps 3G WIFI Router Wireless Gateway (item 150529029964 end time 07-Dec-2010 16:52:47 IST)
2. TP-LINK MR3420 3G/3.75G Wireless N Router - You can connect a Usb modem in the same to get it to work.
eBay India: TP-LINK MR3420 3G/3.75G Wireless N Router 3 Yr. (item 130460423947 end time 07-Dec-2010 10:42:20 IST)
Sorry saw this late, since no one had replied. Picked up a Hame 432R from EkWireless (EBay). Serves my purpose just fine.
