Storage Solutions ultra dma crc error count
impulse1992
Reds under the bed
got this error on hd tune 2 days my system is just a month old
after the error
3 files downloaded were corrupted
changed the cable & everything no change never knew it would happen with just 1 months of usage:mad::mad:
chkdsk doesn't show bad sectors :huh:
will check again
Hdd bench
here's prime 1hr testing
Just saw on HDD sentinel's
Hard Disk Model : ST3500418AS
Received reports about this model
503
Average temperature
33.58 °C / 92.45 °F
Average health
89.05 %
Current temperature:
38 °C / 100.40 °F
Current health:
100 %
The disk temperature is higher compared to the average calculated for this model.
The disk health is higher compared to the average calculated for this model.
My specs
AMD p2 555be
GA 890gpa UD3H
2gb Corsair ddr3
500gb Seagate 7200.12
Detach your HDD cables and reattach them properly. This solved my problem when my HDD's ultra dma CRC error count gone up to 2192 after reattaching cables it stops increasing.
impulse1992 said:
wat about the temps and speed of hdd are they ok??
ps: my pc freezes occasionally is it bcozz of the hdd
The temp in the range of 36 - 42 are quite normal for HDD's. Also the green & LP drives are more cooler than normal ones
Bump!
Guys, HD Tune is giving me the same warning:
I'm not experiencing any sluggishness or file corruption.
I even replaced the SATA cable of this HDD.
Should I be worried? Should I RMA this HDD? :(
Temp: I guess the temp will come down today as I'll be installing a couple of 120mm fans in my PC case.
Do fan positioning well.
I have same he'd and it runs cooler than wd green.
In fact it runs at 32c as my main drive.
Also re attach the sata cables snuggly with enough pressure.
This post pretty much sums it up - http://www.dslreports.com/forum/r24178500-
"It's also important to remember that SMART attributes represent the state of the drive *across its entire lifetime*. 1 CRC error during its lifetime is acceptable."
Those value are not going to reset themselves even if problem is fixed! Most probably 10 CRC errors happened some time in the past. That no. is not increasing (in my case) - So, I guess there's no need to worry. :|
