gaurav3282
Hello people.... I recently bought MSI GTX 660 OC edition(Single Fan) and it works pretty well but the issue is when I start playing Bioshock infinite the temperature rises upto 80 degrees... even after running furmark it reaches 80 deg... my system config is as follows :
i5 2400
4Gb gskill ripjaws
MSI p67-gd 65 (b3)
GX 450 CM PSU...
NZXT Gamma Cabby
Well regarding exhaust its good enough and everything is just neat and clean from inside... Its just regarding temperatures do I need to worry about?This card is not the twin frozer edition.. This can be the reason for the extra heatup?Coz single fan card and twin fan can make a difference... Do I need to add an after market cooler?Also other games run fine and battlefield 3 was played @ 69 Deg MAX temperature... NFS most wanted also @ the same temperature.... Idle temperatures of the card vary from 32-38 degrees...
i5 2400
4Gb gskill ripjaws
MSI p67-gd 65 (b3)
GX 450 CM PSU...
NZXT Gamma Cabby
