PC Peripherals Suggest me SATA to USB/eSATA cable
avi
Hi all !
I have a SATA hard disk and I want to connect to it my Laptop. My laptop has eSata port also. So which one I have to buy ?
- SATA to USB or
- SATA to eSATA ?
thanks in advance :)
If you want speedier transfers eSATA <--> SATA if universal compatibility get the USB <--> SATA converter. Hope this helps.
USB gives about 30-32MBps transfer speed maximum, whereas esata should give normal SATA speed. Havnt tried eSATA though. Correct me if I'm wrong.
^^Yeah it definitely requires separate power supply, even though eSATA includes power supply same way the USB powers devices. Just get a HDD casing.
u have the following options.
buy
an esata casing which will require extra power through usb port
an esatap casing if your laptop has esata powered port,wont require an extra usb connector
Power Over eSATA USB eSATAp 2.5" HDD Enclosure USB2.0 - eBay (item 160523374951 end time Jan-25-11 00:57:35 PST)
a direct esatap connector or esata connector
Power Over eSATA USB 3.5" eSATAp 22 pin Adapter Cable - eBay (item 150550614822 end time Feb-17-11 00:10:26 PST)
or you can buy a hdd caddy,plus two other cables- (i)usb to esata convertor for laptop that dont have esata II an esata+usb to laptop esata
eSATA/USB to SATA Cable for laptop CD DVD rom drive - eBay (item 200494364630 end time Feb-05-11 21:26:20 PST)
