Suggest a phone <14K
MegaMind
1. Q: Budget?
A: 14k(max.)
2. Q: Preferred Form Factor(flip, bar, slider)?
A: Any
3. Q: Preferred display type?
A: None in particular
4. Q: Do you have any brand preference or dislike? Please name them.
A: None
5. Q: Preferred input method (Touchscreen, QWERTY, etc.)?
A: Touchscreen
6. Q: Camera required or not? If required, please specify type like front camera/flash/etc.
A: Required a 5MP camera.
7. Q: Preferred operating system? (Android, Symbian, iOS, Windows Phone etc).
A: Android
8. Q: Preferred connectivity options? (3G, Wifi, Edge etc).
A: wifi.
9. Q: What is your intended use for this phone(internet, camera, multimedia, mails, etc)?
A: Too much talking, mails and internet.
10. Q: Any other requirements?
A: Don't require dual sim
11. Q: If you have already considered a phone then please mention the model.
A: None
This Phone will be used by my friend who used to talk atleast 10 hours a day on the phone, so the phone should have a decent battery life.
my friend got a xperia U on my suggestion, she got a touchscreen problem with her device , when she reachd the service center , they said many of those phones are coming back due to the same issue . i liked the phone, was also going to buy it, but then later changed my mind and budget , and went for Samsung galaxy s Advance
even my friend's xperia U has touchscreen issues.
:/ that's really sad then, anyhow, there are some other phones as well, like the HTC one V , single processor clocked at 1 ghz, but a bit sluggish, go for a dual core from the likes of samsung if you are not much into looks,( i feel all samsung phones look exactly the same, just few minor tweaks here and there) but you get your money's worth.
Ohh. Thats really bad. Didn't know that Xperia U was facing issues. Anyways thanks for the heads up. So if Sony is acknowledging the issue, what timeline have they given to fix the already sold phones? As pratz suggested, you can look for Htc One V, Galaxy S advance, Xperia J and Xperia Sola if you increase your budget a bit.
