APC replaced my faulty BR1000 for the 12th time yesterday charged it for a whole 20 hrs powerchute is saying its 100% charged.Now i have this problem when i connect the APC directly to the mains Powerchute said APC is "providing AVR boost" and it was "boosting" for 20+ mins continuously the voltage was around 194V-202V so the actual voltage would be much less.After 20 mins the voltage dropped below 190V and APC put the PC into hibernate after 2 mins(default is 5mins but i reduced it to 2).
This low voltage thing stays for hours on end and my super sensitive APC ups wont let me keep the PC ON for me to do anything.So APC advised me to get a stabilizer , after starting a thread here i bought a vguard DIGI 100(3Amps,1Kva) stabilizer which kept the voltage near 220V ALL the time.DIGI 100 worked flawlessly for 92 days and my UPS too did not go kaput for 3 Months then only i noticed my backup has reduced drastically no matter how many times i charged i was not even getting 5 mins backup.So called APC again they now say its DIGI 100's fault its only 3 amps while the UPS is 6 amps so it wont charge.They sent a engineer to my house he too says i should have bought a 2 Kva(6amps) stabilizer not 1 IKva(3amps).
So i decided to go for Vguard 4 Kva 12 amps AC stabilizer model no VG D400
Rs 4700 and i contacted vguard service center they say its designed for compressors not for pc/Ups and there will be delay when it boosts the voltage that will prove disastrous for my APC and are advising me to go for DIGI 200 which is 2 Kva, 6 amps (Rs4400).
When i bought the DIGI 100 no one told me about the amp thing and seems like i wasted Rs2500 on it.... dont wanna do the same mistake again please advise me which stabilizer to go for thanks:huh:
