sharing wireless internet connection
Teenu_Alex
I have a 3.5g SIM card internet (7.2mps) USb modem wireless connection fixed in my system. there are other 2 guest in my room with 2 system.
pls let me know how to share internet connection among this three pc.
You have not mentioned the OS in your computer. Anyway, assuming that it is windows, and assuming that all the computers are wifi enabled, internet sharing should be very simple. Just open Network settings from your control panel, and hunt around for the option to create an Ad Hoc Network. Windows should guide you about the rest of the details.
Make sure the computers firewalls are open for new network connections..... also in the router if mac filter is enabled, join the two systems and then ask wireless manager to find the network
