Budget 21-30k Please suggest - New Home PC for 30k
wasif
Recruit
  1. What is your budget?
    • 30K
    • Buying a new PC
    • NA
    • Processor - Intel i3 3420/3220
    • RAM - Kingston HyperX 1600mhz 4gb
    • PSU - Corsair cx43072
    • HDD - wd caviar blue 500gb
    • DVD Drive - HP
    • Cabinet - Cooler Master Elite 310
    • Keyboard - Dell KB212 Quiet
    • Mouse - Logitech standard
    • Monitor - Dell 1930 18.5"
    • No, won't be upgrading.
    • Mumbai [Lamington Road]
    • Open to online purchase [Flipkart]
    • No
    • Gaming
    • Browsing
    • Desktop Processing
    • Watching HD movies
    • Downloading
    • Don't want to buy AMD/Transcend products.
    • NFS
    • Fifa
    1. Gaming - 1280x728
    2. Desktop - 1366 x 768
    • No
    • Windows 7 64 bit
    • Windows 8 64 bit
P.S. most of the components that i have chosen are from TE PC Buying Guide T1 2013.
Just need help with motherboard & graphics card selection, although i'm open to changes in the existing config.
Yup i know about the stock cpu cooler....just wanted to know if a cpu cooler like CM Hyper 212 would be needed to keep the cpu temp under control....
But, thanks for your inputs, i'll stick with the stock cpu cooler :)
