Nokia N82 Hard Reset..
To do a fully hard reset you must switch off your N82, and then do the following combination:
1. Hold down the following three buttons: Green (the call answer button), * button, and '3' button.
2. While holding these buttons, hold the power button for a second to switch on the phone.
3. Release when the phone shows the nokia hands logo
It may take a few attempts and very flexible fingers.
the popular code "*7370#" is to reset the phone to factory settings, and not a fully hard reset and the code "*7780* is for a soft reset [original settings].
source:
Nokia Official support forum
EscSysRq said:
worked many times for n6600...quite an old trick....................
well my n82 was behavin really wierd from past 2 days..
whenever i tried to open nokia maps it would hang.
in other nokia forums it was mention to type the number codes to do the hard reset... i kept on trying but nothin did good to my cell..
i thought of giving a one hard look at the google search once more and found this...
as it helped me, i guess it would help someone too. hence posted here :)
Confirmed. Works on N81 aswell.
Hold these 3 buttons - Call (Green) Button + 3 + star
switch off while holding em
switch on while holding em
wait until the nokia logo comes
no need to hold buttons while u switch off laa :)
