Need smartphone with hot swappable mem card slot
Discussion in 'Mobile Phone Buying Advice' started by htnakirs, Jan 11, 2013.
  1. htnakirs
    Offline
    htnakirs Upgraded User
    a cam with flash ,
    adobe flash support
    are also desirable .
    any suggestions
  2. ALPHA17
    Offline
    ALPHA17 Big man with a mouth
  3. 2kool2btrue
    Offline
    2kool2btrue Privileged Users
    There are lots of phones which fulfill your criteria. How much are you willing to spend? Which OS? What's your intended use? Please use the template as ALPHA17 has suggested
Similar Threads
Forum Title Date
Mobile Phone Buying Advice URGENT NEED OF SMARTPHONE..BUYING TOMORROW Feb 25, 2014
Mobile Phone Buying Advice Need help buying a smartphone May 28, 2013
Mobile Phone Buying Advice Need help deciding between these smartphones May 6, 2013
Mobile Phone Buying Advice Urgently Need Help for Buying Smartphone Feb 15, 2013
Mobile Phone Buying Advice A friend needs a smartphone at less than/equal to 15K. Dec 20, 2011
Share This Page
