Mali-400 MP vs Adreno 220 vs ULP GeForce vs SGX 540?
AFAIK
Mali-400>SGX 540>Adreno 220>GeForce ULP
But you will not find much difference between any of these in real world performance as all these belong to the same generation.
Just get the phone you like the most,dont go by the benchmarks
In some phones an overclocked version of Adreno is being used . I guess HTC uses an Overclocked version .
http://www.anandtech...20-benchmarks/2
Mali 400>Adreno 220>SGX 540>Geforce ULP
Also keep in mind the resolution these GPUs are rendering. For example, benchmarks of SGX 540 on 800x480 screen will be higher than 960x540 screen.
The SGX540 in Galaxy Nexus is clocked at 400 Mhz IIRC, and in Galaxy SII I9100G its 384 Mhz and in others its 300 Mhz.
Adreno 220 ~ Mali 400 match, saw Adreno 220 ahead in some.
Geforce ULV comes next
PowerVR SGX540 comes next
Is this Mali the same as ours in tablet? or there is a difference?
---------- Post added at 09:27 AM ---------- Previous post was at 09:08 AM ----------
I did GLBenchmark 2.1 Egypt(high) and Got 35fps. Is this normal?
It depends on the implementation of the gpu, whether it's a single core or dual or quad. Also clock frequencies play an important part too.
Sent from my SGH-i917 using Board Express
