Budget 10-15K Looking for a mid range android
flash23
1. Budget?
A: 13k to 15k
2. Preferred Form Factor(flip, bar, slider)?
A: Bar
3. Preferred display type?
A: TFT
4. Do you have any brand preference or dislike? Please name them.
A: Only established brands like sony, samsung etc ie no micromax and the likes
5. Preferred input method (Touchscreen, QWERTY, etc.)?
A: Touchscreen
6. Camera required or not? If required, please specify type like front camera/flash/etc.
A: Required with Flash. The cam quality should be good not expecting brilliant
7. Preferred operating system? (Android, Symbian, iOS, Windows Phone etc).
A: Andriod
8. Preferred connectivity options? (3G, Wifi, Edge etc).
A: 3G wifi
9. What is your intended use for this phone(internet, camera, multimedia, mails, etc)?
A: My first android - mostly browsing and media, no heavy gaming
10. Any other requirements?
A: Very very inclined towards dual sim. I have two active sims, will getting a single sim phone be worth carrying the extra phone around?
11. If you have already considered a phone then please mention the model.
A: Xperia M dual, Xperia L, Samsung Grand quattro
Been a Nokia N73 user for around 6 years, its starting to dye out. Since I will be having two sim cards in near future, iam very inclined towards m dual, but in comparison with L lesser internal memory.
will M's 4gb will enough for normal usage considering i wont be playing any heavy games also is M's camera good enough. The only flaw i find in L is that it has no dual \sim version, is it so better than M dual that i should carry around second phone also along.
Also need a opinion on Grand quattro, since its quad core wouldnt it be battery starved? Also I find it a bit large, which I dont prefer.
Need an opinion on their music quality, I have sansa zip and would really like the phone to be on par.
Are there any flaws that I am missing in any of the phones?
I would really appreciate any input.
Thanks.
Sony L
HARDWARE
System chip: Qualcomm Snapdragon S4 Plus MSM8230
Processor: Dual core, 1000 MHz, Krait
Graphics processor: Adreno 305
System memory: 1024 MB RAM
Built-in storage: 8 GB
Pros
Big display (4.3 inches)
High-resolution camera (8 megapixels)
Dual core processor
Lots of RAM (1024 MB RAM)
NFC
Three difference in Xperia M - Camera is 5MP, 4GB ROM and display is 4 inch
LG Optimus L9
HARDWARE
System chip: TI OMAP4430
Processor: Dual core, 1000 MHz, ARM Cortex-A9
Graphics processor: PowerVR SGX540
Built-in storage: 4 GB
Pros
Very big display (4.7 inches)
Dual core processor
Fast mobile data support (4G)
NFC
Screen size is not a big of an issue here for me. A good camera is anyway welcome.
The only thing I am concerned is the internal memory. Since I have never used an Android before I dont have an idea about memory requirements, but one is for sure that I wont be playing any heavy games only the usual puzzle sorta ones. So is M dual's 4gb enough or is it deal breaker.
Also need a reliable and durable phone, as I wont be upgrading it for a long time.
Don't go device below 1GB RAM. 4GB internal storage is also good enough if not using for heavy gaming. You can add 16/32GB class 10 card and use it to install more apps and store data.
