Hi,
Please somebody suggest me the best possible config under this budget. This is primarily for my wife and 2 kids. Appreciate all your help.
- What is your budget?
- 25-30K
- Do not have one
- Noe Valid
- Need everything, CPU, Monitor, PSU, Speakers
- No
- NCR
- Open to online purchase
- No
- Browsing
- Desktop Processing
- Home and Family Usage
- No
- Whath is your preferred monitor resolution for gaming and normal usage
- Good enough
- Yes/No
- Windows 7 or 8
