CPU/Mobo High-Low beeps while running heavy softwares and games
Rahul++
SuperUser
Hello,
My computer has following configuration :
Intel Core 2 Duo E4600
Abit IP35-e
Palit 9800GT 512MB
G.Skill PI Black 2x2GB 800MHz RAM..
I know it's outdated and need to get myself upgrade now. But I want to know which of the above is faulty. Whenever I play games life F1 2010 or 2011 or start rendering videos in Powerdirector. I get some alternative high-low beeps (kinda Siren). Beeps stops sounding when I close that perticuler application or a game..
I've managed to get temperatures from tools like Core Temp and GPU Temp.. Here are the results :
CPU Temperature (Around 51C for both cores)
GPU Temperature (Around 59C)
I don't know actually which hardware is forcing motherboard to beep.
I guess you have enabled either of these in BIOS â–º Temperature Monitor
under the A-bit uguru panel. Just check those sections and disable the beep, or increase the beep temp of the system. Here is a reference
Well, the last time I heard such beeps, system GPU was overdrawing power from the PSU. It was a puny CM 400 PSU against the Radeon 4870. I could never figure out the source of beeps (Mobo, GPU or PSU - long shot, but possible) though it was gone after the PSU was replaced.
