Help! Screwed up trying to install Archlinux on Seagate GoFlex Net
Discussion in 'Networking' started by tommy_vercetti, Apr 26, 2012.
  1. tommy_vercetti
    tommy_vercetti Well-Known Member
    Apr 20, 2006
    958
    53
    Help! Screwed up trying to install Archlinux on Segate GoFlex Net
    #varkey #dinjo #dheerajjotwani
    I followed this guide http://archlinuxarm....gate-goflex-net, the things that I did differently are highlighted, currently the device is happily blinking away(green)
    Unplug all disk drives.
    Take a note of the MAC address (usually it is on a label on the underside of the device, in the form uu:vv:ww:xx:yy:zz).
    With only the drive you intend to install Arch Linux ARM to plugged in (all data will be erased), switch on the power.
    If using a SATA hard drive, put the hard drive in right slot (if you're looking from the front.)
    Log in to Seagate GoFlex Net over SSH.
    Stop the Pogoplug software so it doesn't interfere with the install process:killall hbwd
    Start fdisk to partition the USB or SATA drive:
    /sbin/fdisk /dev/sda
    At the fdisk prompt, delete old partitions and create a new one:
    Type o. This will clear out any partitions on the drive.
    Type p to list partitions. There should be no partitions left.
    Now type n, then p for primary, 1 for the first partition on the drive, and then press ENTER, accepting default values.
    Exit by typing w.
    Create the ext3 filesystem:
    cd /tmp
    wget http://archlinuxarm....pogoplug/mke2fs
    chmod 755 mke2fs
    ./mke2fs -j /dev/sda1
    mkdir alarm
    mount /dev/sda1 alarm
    Download and install Arch Linux ARM:
    cd alarm
    wget http://archlinuxarm....e-latest.tar.gz
    tar -xzvf ArchLinuxARM-armv5te-latest.tar.gz # This will take a long time # I think I skipped this step [​IMG]
    rm ArchLinuxARM-armv5te-latest.tar.gz # I think I skipped this step :-(
    sync # Takes a while if you are using a flash drive
    Unmount the drive:
    cd ..
    umount alarm
    Download the U-Boot Install Toolkit (UBIT) environment
    cd /tmp
    wget http://jeff.doozan.c...ex/v0.6/uInitrd
    wget http://jeff.doozan.c...v0.6/ubit_start
    chmod +x ubit_start
    Start the UBIT environment where the prompt will read: ubit0-6:~#
    ./ubit_start
    Update the U-Boot bootloader and move a copy of the OE U-Boot into unused NAND memory:
    chain_install goflexnet
    chain_revert
    uboot_uptodate
    You need to set your MAC address to the value you noted earlier
    ethaddr uu:vv:ww:xx:yy:zz
    Install the rescue system
    on /dev/sda1 ubit_write # Gave error, still the hero I'm I proceeded to the next command [​IMG]
    Mark the partition with the special label "rootfs":
    tune
    2fs -L "rootfs" /dev/sda1
    Leave the UBIT shell, and reboot into Arch Linux ARM
    exit
    /sbin/reboot
    Console Log
    login as: root
    password:
    -bash-3.2# killall hbwd
    -bash-3.2# /sbin/fdisk /dev/sda
    Command (m for help): o
    Building a new DOS disklabel. Changes will remain in memory only,
    until you decide to write them. After that the previous content
    won't be recoverable.
    Warning: invalid flag 0x00,0x00 of partition table 4 will be corrected by w(rite)
    Command (m for help): p
    Disk /dev/sda: 8076 MB, 8076132352 bytes
    255 heads, 63 sectors/track, 981 cylinders
    Units = cylinders of 16065 * 512 = 8225280 bytes
    Device Boot Start End Blocks Id System
    Command (m for help): n
    Command action
    e extended
    p primary partition (1-4)
    p
    Partition number (1-4): 1
    First cylinder (1-981, default 1): Using default value 1
    Last cylinder or +size or +sizeM or +sizeK (1-981, default 981): Using default value 981
    Command (m for help): w
    The partition table has been altered!
    Calling ioctl() to re-read partition table
    -bash-3.2# cd /tmp
    -bash-3.2# wget http://archlinuxarm.org/os/pogoplug/mke2fs
    Connecting to archlinuxarm.org (206.217.130.189:80)
    mke2fs 100% |*******************************| 799k 00:00:00 ETA
    -bash-3.2# chmod 755 mke2fs
    -bash-3.2# ./mke2fs -j /dev/sda1
    mke2fs 1.41.9 (22-Aug-2009)
    Filesystem label=
    OS type: Linux
    Block size=4096 (log=2)
    Fragment size=4096 (log=2)
    492880 inodes, 1969962 blocks
    98498 blocks (5.00%) reserved for the super user
    First data block=0
    Maximum filesystem blocks=2017460224
    61 block groups
    32768 blocks per group, 32768 fragments per group
    8080 inodes per group
    Superblock backups stored on blocks:
    32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632
    Writing inode tables: done
    Creating journal (32768 blocks): done
    Writing superblocks and filesystem accounting information: done
    This filesystem will be automatically checked every 25 mounts or
    180 days, whichever comes first. Use tune2fs -c or -i to override.
    -bash-3.2# mkdir alarm
    -bash-3.2# mount /dev/sda1 alarm
    -bash-3.2# cd alarm
    -bash-3.2# wget http://archlinuxarm.org/os/ArchLinuxARM-armv5te-latest.tar.gz
    ArchLinuxARM-armv5te 100% |*******************************| 149M 00:00:00 ETA
    -bash-3.2# sync
    -bash-3.2# cd..
    -bash: cd..: command not found
    -bash-3.2# cd ..
    -bash-3.2# unmount alarm
    -bash: unmount: command not found
    -bash-3.2# umount alarm
    -bash-3.2# cd /tmp
    -bash-3.2# wget http://jeff.doozan.com/debian/goflex/v0.6/uInitrd
    Connecting to jeff.doozan.com (69.163.187.226:80)
    uInitrd 100% |*******************************| 3911k 00:00:00 ETA
    -bash-3.2# wget http://jeff.doozan.com/debian/goflex/v0.6/ubit_start
    Connecting to jeff.doozan.com (50.116.34.13:80)
    ubit_start 100% |*******************************| 2238 --:--:-- ETA
    -bash-3.2# chmod +x ubit_start
    -bash-3.2# ./unit_start
    -bash: ./unit_start: No such file or directory
    -bash-3.2# ./ubit_start
    17220 blocks
    Entering UBIT environment
    No valid U-Boot environment exists.
    You need to reboot once to let U-Boot set its default environment
    before the ethaddr setting can be updated, either directly or
    with a cached value.
    To cache a value, run:
    UBIT v0.6 by peaslaker 2010.11-00125-ga21bcca
    ubit0-6:~# chain_install goflexnet
    UBIT.CHAIN:goflexnet
    UBIT.CHAIN:/usr/share/ubit/original/goflexnet.kwb writing to 0x380000 of /dev/mtd1
    1+0 records in
    1+0 records out
    UBIT:bl: /usr/share/ubit/original/goflexnet.kwb checksum 5cbbbca7693c5939836349bbd7f270e8 -
    Erase Total 4 Units
    Performing Flash Erase of length 131072 at offset 0x3e0000 done
    Writing data to block 28 at offset 0x380000
    Writing data to block 29 at offset 0x3a0000
    Writing data to block 30 at offset 0x3c0000
    Writing data to block 31 at offset 0x3e0000
    1+0 records in
    1+0 records out
    UBIT:bl: u-boot checksum match OK.
    ubit0-6:~# chain_revert
    /usr/share/ubit/original/goflexnet.kwb.md5
    1+0 records in
    1+0 records out
    UBIT:bl: u-boot.5cbbbca7693c5939836349bbd7f270e8.kwb checksum 5cbbbca7693c5939836349bbd7f270e8 -
    Erase Total 4 Units
    Performing Flash Erase of length 131072 at offset 0x60000 done
    Writing data to block 0 at offset 0x0
    Writing data to block 1 at offset 0x20000
    Writing data to block 2 at offset 0x40000
    Writing data to block 3 at offset 0x60000
    1+0 records in
    1+0 records out
    Writing data to block 4 at offset 0x80000
    ubit0-6:~# uboot_uptodate
    Existing firmware identified as matching: /usr/share/ubit/original/goflexnet.kwb.md5
    UBIT:bl: u-boot checksum did not match.
    Writing latest goflexnet firmware to /dev/mtd0
    0+1 records in
    1+0 records out
    UBIT:bl: /usr/share/ubit/firmware/goflexnet.kwb checksum b43339faeb1d3924fa09aae0d0723065 -
    Erase Total 4 Units
    0+1 records in
    1+0 records out
    ubit0-6:~# ethaddr 00:10:75:26:8E:AA
    Cached ethaddr value set to: 00:10:75:26:8E:AA
    ubit0-6:~# on /dev/sda1 ubit_write
    UBIT:eek:perating on /dev/sda1
    Output directory '/tmp/7caae93163da50f03ac46f598ec13f7a/boot' does not exist
    ubit0-6:~#
    The device gets detected on http://goflexnet.pog...g.com/view.html but no SSH option, cannot connect to it using SSH, it is still happily blinking [​IMG]
  2. vivek.krishnan
    vivek.krishnan Workaholic + Teetotaler + pfSense FTW.
    Veteran
    Dec 18, 2009
    4,742
    428
    [font=helvetica, arial, sans-serif]#[member='varkey'] Help needed urgently.[/font]
  3. varkey
    varkey Well-Known Member
    Sep 8, 2006
    2,965
    187
    So you skipped the most important step of extracting the rootfs! [​IMG]
    Connect the pendrive to a linux system, mount it and as 'root' (not sudo), extract the files to the pendrive with the same command 'tar -xzvf ArchLinuxARM-armv5te-latest.tar.gz' Unmount it. Do a file system check just in case and connect it to the GoFlex Net. It should boot, hopefully. [​IMG]
    The second thing you missed is the rescue system, if that was successful it would have booted into the rescue system automatically in this case.
  4. tommy_vercetti
    Apr 20, 2006
    958
    53
    Thanks! for the instructions #[member='varkey'], I do not have a Linux system is it ok, if I create in VMWare and then try to do so, how do or can I go back to the old pogoplug sytem? #[member='vivek.krishnan'], thanks!
  5. tommy_vercetti
    Apr 20, 2006
    958
    53
    I'm up thanks to those instructions #[member='varkey'], can you tell me how to install the recovery? Also how do I start fresh?
  6. varkey
    Sep 8, 2006
    2,965
    187
  7. tommy_vercetti
    Apr 20, 2006
    958
    53
  8. tommy_vercetti
    Apr 20, 2006
    958
    53
    #[member='varkey'], sorry to trouble you, help needed, I tried to install the recovery from this page http://www.varkey.in/2011/09/seagate-goflex-net-installing-rescue-system/ it gave me error regarding uBoot not being updated, I updated uBoot from here http://projects.doozan.com/uboot/ and then again tried to install the recovery, it gave some error regarding unknown uBoot, used the no-uBoot-check parameter and was successfully able to update it, it got updated successfully. Then ran the following command
    fw_setenv rescue_bootcmd 'if test $rescue_installed -eq 1; then run rescue_set_bootargs; nand read.e 0x500000 0x100000 0x400000; bootm 0x500000; else run pogo_bootcmd; fi'
    which also completed without any error, after this I wanted to try 'After this you can shutdown the device, remove the USB drive and restart, it will successfully boot into the rescue system.' so I disconnected the power to it, removed USB drive and connected power, I see that it is getting a proper IP, but the LED is off, blinks at start and then then turns off, I cannot connect to it using ssh. What do you mean by recovery, does it mean I need to set netconsole, is that what recovery means, with the Pogoplug shit on it I could connect to it without any drives, now with this ArchLinux, I cannot connect to it without any drives, is there any guide or steps wihtout enabling netconsole to go back to Pogoplug
    #[member='dinjo'], #dheerajjotwani
    Thanks in advance, I love my RT-N16, can download Torrents/eMule/HTTP, also doubles up as a DLNA server, can use a 3G modem to connect to internet and distrubute it without going to so much headless(no gui) trouble!
  9. varkey
    Sep 8, 2006
    2,965
    187
    ^ After you updated the uboot to Jeff's version did you run the rescue system installer? And did it boot to ArchLinux with the new uboot?
    The LED is fine, it means that its booting fine, but since you haven't set the proper arch number it will not work. If its getting an IP, are you able to ping it?
  10. tommy_vercetti
    Apr 20, 2006
    958
    53
    Yes, also somewhere in between it also told me that it had set up the arch number to something like 20** and then I followed all the recovery steps and went ahead and removed the usb and restarted it :-(
    I'm not able to ping the IP :-(
    C:\Users\Prashant>ping 192.168.1.13
    Pinging 192.168.1.13 with 32 bytes of data:
    Reply from 192.168.1.10: Destination host unreachable.
    Ping statistics for 192.168.1.13:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
  11. varkey
    Sep 8, 2006
    2,965
    187
    ^ Are you sure that's the IP? If it boots to the rescue system, the IP will probably change. And are you able to boot into ArchLinux *after* you changed uboot?
  12. tommy_vercetti
    Apr 20, 2006
    958
    53
    Not sure about booting!
    1. I tried to update recovery, it told me to update uBoot
    2. I updated uBoot and during update it told me it was setting some Arc number.
    3. Again ran the recovery script it completed without any errors
    4. I then ran the enviorment command that aslo completed and did not give any errors
    5. I did not restart ArchLinux to test it, just plugged out the power, removed USB drive and then connected power to it
    6. The light blinks temporarily and then goes out, the IP is the same as it was earlier 192.168.1.13
    7. I tried to remove the USB, and took the ArchLinux tar and extracted it on a another USB with ext3 partition named rootfs and that also did not work, anymore idea?
    Once again thanks for your help!
  13. varkey
    Sep 8, 2006
    2,965
    187
    Oh k. Not sure what is wrong exactly. If you can post the serial output it would be easier.
    You shouldn't have updated the uboot like that. [​IMG]
  14. tommy_vercetti
    Apr 20, 2006
    958
    53
    Serial output, what is that, how can I enable netconsole
    ASUS RT-N16 -> VAIO Laptop
    -> GoFlex
    Can I somehow put something inside it to get it to boot into ssh? the LED blinks at start and goes off, Serial access how to? any #Mumbai guys willing to help me out?
    What part of this guide will help me? http://forum.doozan.com/read.php?2,5986,5986
  15. varkey
    Sep 8, 2006
    2,965
    187
    ^ You need a serial adapter to get a serial output,open the GoFlex and connect it -- http://www.varkey.in/2011/06/seagate-goflex-net-serial-connection/
    You cannot enable netconsole without a working and booting OS. You can try creating a new rootfs and see if it boots, but there is no way to know exactly what is wrong without seeing the boot log for which you need serial or netconsole. Since netconsole is not possible, only option is the serial console.
  16. tommy_vercetti
    Apr 20, 2006
    958
    53
    Some good news, I copied the uImage and uInitrd to the boot folder, now the goflex boots and the green light keeps blinking, but the internet connection is going to it but it is not getting a IP, any more help?
    Apologies for the trouble
  17. varkey
    Sep 8, 2006
    2,965
    187
    ^ How do you know that its booting? Without seeing the boot log I don't think you will get a definitive solution.
  18. tommy_vercetti
    Apr 20, 2006
    958
    53
    lol, just thought so, since the green light was blinking, will have to wait till I get the serial connector! Anyone in #Mumbai with a working serial connector?
  19. tommy_vercetti
    Apr 20, 2006
    958
    53
    #[member='varkey'], I'm back, the device boots with a ArchLinux on a USB drive, I cannot upgrade uBoot or install recovery, can you help me set up netcat(not sure if this will help as I'm on a unknown uBoot) or installing recovery, I will post the logs soon.
    Trying to update uBoot
    1+0 records in
    1+0 records out
    Erase Total 4 Units
    Performing Flash Erase of length 131072 at offset 0x380000
    MTD Erase failure: Input/output error
    Bad block at 380000, 1 block(s) from 380000 will be skipped
    Bad block at 3a0000, 1 block(s) from 3a0000 will be skipped
    Bad block at 3c0000, 1 block(s) from 3c0000 will be skipped
    Bad block at 3e0000, 1 block(s) from 3e0000 will be skipped
    Writing data to block 32 at offset 0x400000
    ioctl(MEMGETBADBLOCK): Invalid argument
    Data was only partially written due to error
    : Invalid argument
    ubit0-6:~#
    ubit0-6:~# uboot_install goflexnet
    UBIT:bl: backing up /dev/mtd0 to u-boot.38eb11b49b828dc070270680a8a37845.kwb
    Keep your u-boot backups safe.
    0+1 records in
    1+0 records out
    Erase Total 4 Units
    Performing Flash Erase of length 131072 at offset 0x0
    Bad block at 0, 1 block(s) from 0 will be skipped
    Bad block at 20000, 1 block(s) from 20000 will be skipped
    Bad block at 40000, 1 block(s) from 40000 will be skipped
    Bad block at 60000, 1 block(s) from 60000 will be skipped
    Bad block at 80000, 1 block(s) from 80000 will be skipped
    Writing data to block 5 at offset 0xa0000
    Bad block at a0000, 1 block(s) from a0000 will be skipped
    Writing data to block 6 at offset 0xc0000
    Bad block at c0000, 1 block(s) from c0000 will be skipped
    Writing data to block 7 at offset 0xe0000
    Bad block at e0000, 1 block(s) from e0000 will be skipped
    Writing data to block 8 at offset 0x100000
    : Invalid argument
    You had better sort this out before rebooting as the u-boot is now probably corrupt.
    Commands that will be needed:
    - flash_erase /dev/mtd0 0 4
    - dd if=/usr/share/ubit/firmware/goflexnet.kwb bs=512K conv=sync | nandwrite -s 0 /dev/mtd0 -
    - nanddump -nol 0x80000 /dev/mtd0 | md5sum
    Checksum should match: b43339faeb1d3924fa09aae0d0723065 - - /tmp/checksum
    ubit0-6:~#
    [root@alarm /]# blkid
    /dev/sda1: LABEL="rootfs" UUID="18d55cfb-d0ac-416d-b5c4-d369d203b7d3" TYPE="ext2"
    [root@alarm /]#
    [root@alarm /]# fdisk -l
    Disk /dev/sda: 8103 MB, 8103395328 bytes
    250 heads, 62 sectors/track, 1021 cylinders, total 15826944 sectors
    Units = sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disk identifier: 0x0000682a
    /dev/sda1 62 15825499 7912719 83 Linux
    [root@alarm /]#
    [root@alarm /]# mount
    /dev/root on / type ext2 (rw,relatime,errors=continue)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=61680k,nr_inodes=15420,mode=755)
    proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
    sys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620)
    shm on /dev/shm type tmpfs (rw,nosuid,nodev,relatime)
    tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime)
    [root@alarm /]#
  20. tommy_vercetti
    Apr 20, 2006
    958
    53
Share This Page
