Graphic Cards Graphics Card buying Guide October 08
hi guys this is a graphics card buying guide for those who want buy gfx card in near future
Graphics Card Under Rs.2000
XFX 8400GS 256mb-Rs.1700
Specifications:
Model
Brand : XFX
Model : PVT86SYAFG
Interface : PCI Express x16
Chipset Manufacturer :NVIDIA
GPU: GeForce 8400 GS
Core clock: 450MHz
Memory Clock: 533MHz
Memory Size :512MB
Memory Interface: 64-bit
Memory Type : GDDR2
DirectX : DirectX 10
OpenGL : OpenGL 2.0
Ports
D-SUB :1
DVI :1
TV-Out HDTV / S-Video Out
RAMDAC : 400 MHz
Max Resolution: 2560 x 1600
RoHS Compliant: Yes
Dual-Link DVI Supported: Yes
HDCP Ready : Yes
Graphics Card Under 4000
1.XFX 8600GT 256 GDDR3-Rs.4100
Specifications:
Brand : XFX
Model : PVT84JUDD3
GPU : GeForce 8600 GT
Core clock : 620MHz
Stream Processors: 32
Memory Clock : 1600MHz
Memory Size : 256MB
Memory Interface: 128-bit
Memory Type : GDDR3
Ports
DVI : 2
TV-Out : HDTV Out
RAMDAC : 400 MHz
Max Resolution : 2560 x 1600
RoHS Compliant : Yes
SLI Supported : Yes
2.Xpertvision HD3650 512mb GDDR2-Rs.3300
Specifications:
Interface : PCI Express 2.0 x16
Chipset Manufacturer : ATI
GPU : Radeon HD 3650
Stream Processors : 120 Stream
Memory Size : 512MB
Memory Interface : 128-bit
Memory Type : GDDR2
Ports
DVI : 2
RAMDAC : 400 MHz
CrossFire Supported: Yes
HDCP Ready : Yes
Needless to say but in this range 8600GT is faster among the two...but i mentioned HD3650 since its a great buy at that price!!!!
Graphics Card Under Rs 6000
1.MSI HD4670 -Rs.5450
Specifications:
* Bus interface: PCI Express? 2.0
* Memory Support: 512MB GDDR3
* Memory Interface: 128 bit
* RAMDACs: 400 MHz
* 320 Stream Processors
* Full Microsoft? DirectX 10.1 Shader Model 4.1 support
* Dual-link DVI output supports 2560x1600 resolution display
* Dynamic geometry acceleration
* Game physics processing capability
* 4-in-one display support includes CRT, HDMI, Dual-link DVI, and DisplayPort
2.Palit 9600GT-Rs.6300
Specifications:
Brand : Palit
Model : NE/9600T+0152
Chipset Manufacturer : NVIDIA
GPU : GeForce 9600 GT
Core clock : 650MHz
Stream Processors: 64
Memory Clock : 1800MHz
Memory Size : 512MB
Memory Interface : 256-bit
Memory Type : GDDR3
HDMI : 1
DVI : 1
TV-Out : HDTV / S-Video
RAMDAC : 400 MHz
SLI Supported : Yes
Power Connector : 6 Pin
Dual-Link DVI Supported : Yes
HDCP Ready : Yes
3.Xpertvison HD3850 for Rs.5500
Specifications:
# Chipset Manufacturer: ATI
# Stream Processors: 320 Stream Processing Units
# DirectX: DirectX 10.1
# OpenGL: OpenGL 2.0
# DVI: 2
# TV-Out: HDTV / S-Video / Composite Out
# RAMDAC: 400 MHz
# Max Resolution: 2560 x 1600
4.Palit 9600GSO 384mb for Rs.5500
Specifications:
* Bus interface: PCI Express 2.0 Support
* Memory: 384MB
* Memory Interface: 192 bit
* RAMDACs: 400 MHz
* NVIDIA® unified architecture with GigaThread™ technology
* Full Microsoft® DirectX® 10 Shader Model 4.0 support
* PCI Express 2.0 Support
* 16x full-screen anti-aliasing
* True 128-bit floating point high dynamic-range (HDR) lighting
* NVIDIA® Quantum Effects™ physics processing technology
* Two dual-link DVI outputs support two 2560x1600 resolution displays
* NVIDIA® PureVideo™ HD technology
* OpenGL® 2.1 support
* NVIDIA ForceWare® Unified Driver Architecture (UDA)
* Built for Microsoft® Windows Vista™
* NVIDIA® Lumenex™ Engine
* NVIDIA® nView® Multi-Display Technology
* Discrete, Programmable Video Processor
* Hardware Decode Acceleration
* Spatial-Temporal De-Interlacing
* High-Quality Scaling
* Inverse Telecine (3:2 & 2:2 Pulldown Correction)
* Bad Edit Correction
* Video Color Correction
* Integrated SD and HD TV Output
* Noise Reduction
* Edge Enhancement
Here Palit 9600GT outperforms all other cards...
Graphics Card under 8000
Sapphire HD4830 for rs.8000(approx via KMD)
Specifications:
Brand : SAPPHIRE
Model : 100265L
Chipset Manufacturer :ATI
GPU : Radeon HD 4830
Stream Processors : 640 Stream Processing Units
Memory Size : 512MB
Memory Type : GDDR3
DirectX : DirectX 10.1
OpenGL : OpenGL 2.1
HDMI :1 via Adapter
DVI : 2
TV-Out : HDTV / S-Video Out
RAMDAC : 400 MHz
CrossFire Supported : Yes
Link : Newegg.com - SAPPHIRE 100265L Radeon HD 4830 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Desktop Graphics / Video Cards
Palit 9800GT for Rs.7800
Specifications:
Brand : Palit
Model : NE/9800TXT352
GPU : GeForce 9800 GT
Core clock : 600MHz
Stream Processors : 112
Memory Size : 512MB
Memory Type : GDDR3
Ports
DVI :2
RAMDAC : 400 MHz
SLI Supported : Yes
System Requirements: Minimum 450W or greater system power supply (with 12V current rating of 26A)
HDCP Ready : Yes
Graphics Card Under Rs.10000
Palit HD4850 for Rs.9050(New price!!!-->Rahul theitwares.com)
KING OF MID GAMING CARDS
Specifications:
* Memory Interface: 256 bit
* Memory Clock: 1986MHz (993 x 2)
* Core Clock: 625MHz
* RAMDACs: 400 MHz
* Full Microsoft: DirectX? 10.1
* Shader Model: 4.1 support
* Dual Dual-link DVI outputs support 2560x1600 resolution displays
Graphics Card Under Rs.20,000
Palit ATi Radeon HD4870 512mb Sonic Dual Edition for Rs.17,700
Specifications:
* Memory Support: 1GB GDDR5
* Sonic Memory / Core Clock: 3800MHz (950 x 4) / 750 MHz
* Turbo Memory / Core Clock: 4000MHz (1000 x 4) / 775 MHz
* RAMDACs: 400 MHz
* Full Microsoft DirectX 10.1 Shader Model 4.1 support
* HDMI function via dongle
Another option would be GTX 260 but HD4870 outperforms it so i'm not mentioning the specifications here....
HD4870 1GB edition available for 20990....
NO BUDGET CARDS:
1.Sapphire HD4870X2 2GB GDDR5(Fastest Card on Earth)-Rs.30,000
Brand: SAPPHIRE
Model :100251SR
GPU : Radeon HD 4870 X2
Stream Processors: 1600 (800 x 2) Stream
Memory Size : 2GB
Memory Interface : 512-bit (256-bit x 2)
Memory Type : GDDR5
Ports
HDMI : 1 via Adapter
DVI : 2
RAMDAC : 400 MHz
Power Connector : 6 pin / 8 pin
HDCP Ready : Yes
2. EVGA GTX280 1GB GDDR3-32,000(2ND FASTEST CARD)
Specifications:
GPU : GeForce GTX 280
Core clock: 691Mhz
Stream Processors : 240 processing cores
Memory Clock : 2430MHz
Memory Size : 1GB
Memory Type : GDDR3
SLI Supported : Yes
Cards coming soon in the list-->HD4850X2(under 20k)..will add after confirmed pricing
SO here is a guide for all ur gfx needs..dont forget to say thanx in case u like it...suggestions r welcomed!!
RoBoGhOsT said:
man 9800gx2 is good for under 20k , it costs 16k from kmd .
I think HD4870 is much better than 9800GX2 n it consumes lot less power too i guess....m not 100% sure since havent used ne of those 2 cards...but if u ppl like then i'll add it too
Yup..Nice thread..But you should replace that xfx 8600gt with a 9500gt..8600gt is kinda outdated now..9500gt is better and costs the same..
Good work there.
But consider including the 9800GX2 as well. It is a card worth considering apart from high power consumptions. ;)
Are you a Palit fanboi?? :p Include other major brands like Sapphire, GeCube, Asus, MSi etc.
9500GT GDDR3 costs 4800...at tht price i couldnt include it in under 4k nor under 6k since its no where compared 9600GT n HD4670
Gunman said:
Good work there.
I'm no Palit Fanboy...Palit provides best price to perforance ratio..
Eg: Palit 9600GT costs 6100(mumbai price)
Evga\XFX 9600GT costs around 8000 at tht price i can get Palit 9800GT which will outperform 9600GT quite easily no matter which brand....neways if u ppl still think i should include i'll put a slash n include other brands...but then i will have to include 9600GT in under 8000 category n its no match for 9800GT....
N i have included brands like EVGA,Sapphire where price to performance ratio isnt a barrier!!!
Well suggest the better brands with price so that i can include it in my guide!!!
the normal Zotac 9600 GT is clocked at 675 Core. this is an OC of 25Mhz over the standard reference 9600GT. The amp edition is clocked even higher.
Can u provide any links or shop name for 9600GT around price u have menitoned?
